Mirror lens question
Discussion in 'Photography Beginners' Forum' started by Sodak, Apr 10, 2009.
  1. Sodak
    Sodak TPF Noob!
    Jan 28, 2009
    104
    I'm looking on ebay for new lenses and I see this:
    Bower 500mm/1000mm Mirror Lens.
    Buy it now $169.
    My gut tells me that these cant be worth a hoot, can they? Does anyone have experiences they can share using this type of lens?
  2. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    No good. Just search for previous topics.
  3. tirediron
    Jul 8, 2005
    40,900
    12,419
    Victoria, BC
    They're heavy, slow (Typically f8) and especially in the cheaper ones, really dodgy optical quality. Unless you have to pack 1000mm into a relatively small package, can shoot in very bright light, and aren't super-fussy about the overal quality, walk away.
  4. Sodak
    Sodak TPF Noob!
    Jan 28, 2009
    104
    Thanks. I didn't remember seeing them talked about in this forum, but I've only been around about 3 months.
    I shall flee in earnest with my cash secured.
  5. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    Mirror lenses are a mixed bag. On the plus side:
    1. generally reasonably high resolution, particularily in the center
    2. very light for their focal length
    3. very compact for their focal length
    4. generally focus closer than conventional lenses of the same focal length
    On the negative side:
    5. very prone to flare
    6. the world's worst bokeh
    7. generally slow (modestly small maximum aperture)
    8. no iris to adjust aperture; you always shoot at maximum
    9. with very, very, very few exceptions (I believe there was only 1), they are manual focus.
    The bokeh (quality of out-of-focus portion of image) problem manifests itself as donut or crescent shaped out-of-focus highlights. These can overlap creating a rather annoying background when shooting against a complex background (e.g. leaves with small spots of sky showing through). A single bird against a blank sky or with a few clouds, on the other hand, doesn't generaly display any flaws.
    #1 and #5 mix to yield what you see as "sharpness". Sharpness doesn't exist in the real world; it is the impression you get when your brain combines the contrast between the tones on either side of the edge with the width of the edge as the one tone blurs into the other. When shooting in low flare situations, mirror lenses tent to produce images that look "sharp". In high flare situations (e.g. backlight, reflective objects in the shot, ...) the percieved sharpness drops of fast.
    Add to all of this that the Bower brand is not known for high quality optical, the lens you list is probably not a great option.
  6. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    The speed isn't really an issue, most outdoors shooting is done at f8 ( heck LF often shoot at f16 or F22 regardless of the light ) or slower.
  7. NateWagner
    NateWagner TPF Noob!
    Jun 2, 2008
    1,240
    St. Petersburg, FL
    of course, the other thing is you can't go below f8 either. It is f8 or nothing.
bower 500mm photos
