mirror lock up
Discussion in 'Photography Beginners' Forum' started by swmocity, Sep 30, 2008.
  1. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    whats the purpose of this feature...ive been reading about it...still dont understand it though
  2. dklod
    dklod TPF Noob!
    Sep 24, 2007
    344
    In a tent outside the gates of hell
    I think its to further reduce camera shake or reduce the vibration of it swinging back during long exposures. Lock the mirror, set the self timer (or vice versa), press the shutter..
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    it's for shootings at about 1/4th-1/60th of a second when you're on a tripod because the reflex mechanisim is what creates the most vibration at taht point and when the mirror is locked up, the only thing moving is the curtain which makes very little vibration compare to the mirror.
  4. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    That's correct.
    Mirror lock up should be used when you have the camera on a tripod and are using a remote (or the self timer). The whole idea of using a tripod is so that you are not touching the camera while it fires, and that it's very still which should maximize the sharpness of your photo, especially at slower shutter speeds.
    The camera has moving parts, the mirror and the shutter...and these can cause vibrations, which can cause blurry images, especially at certain shutter speeds and with longer lenses.
    So mirror lock up is a mode that will trigger the mirror to fire well before the shutter, allowing the camera a short time to settle down before the exposure is taken.
  5. swmocity
    swmocity TPF Noob!
    May 3, 2008
    469
    Houston
    is is a downside to use it all the time?
  6. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    If you are using the camera on a tripod, then it might be a good idea to use it all the time. It's wouldn't really be practical to use while holding the camera in your hand...firstly, it would do absolutely no good because your hands will be moving the camera more than the mirror does and secondly, you would need to press the shutter button twice, once to flip up the mirror and again to fire the shutter...and you wouldn't be able to see out of the viewfinder when the mirror is up. Believe me, it's very annoying when you forget to turn MLU off, and then pick up the camera to get a shot and press the button...only to find out that you missed your chance.
  7. Overread
    May 1, 2008
    24,064
    4,171
    UK - England
    many a canon user curses the direct print button - and wishes for a MLU on/off button!
    Its not good for tracking fast moving targets - birds, planes etc - static subjects really are its only area since you lose time as you go through using the camera - so a moving target can be out of frame/focuse by the time the shutter is used
  8. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Amen!
    If you are shooting a moving subject, you would need to be using a faster shutter speed to avoid blur...so MLU probably wouldn't be needed anyway. MLU is really only suited to shooting still subjects like landscapes or still life etc.
  9. dklod
    dklod TPF Noob!
    Sep 24, 2007
    344
    Does it automatically activate live view on Nikons and Canons that have it??
  10. reg
    reg TPF Noob!
    May 28, 2008
    1,487
    Stuck inside of Mobile with the GTFO Blues Again
    No, but the live view button does.
    :er:
  11. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I don't use it much anymore due to my broken LCD - it's a pain in the ass to turn it on, and even harder to turn it off without being able to see the LCD.
    Can anyone show me a blurry picture, and a not-blurry picture of the same thing where mirror lock-up is the only variable?
    I know what it's supposed to do - but I have never had a photo come out less sharp because of mirror shake. Does anyone have a photo that shows mirror induced vibration?
  12. reg
    reg TPF Noob!
    May 28, 2008
    1,487
