Monitor Calibration
Discussion in 'Photography Equipment & Products' started by Naicidrac, Mar 14, 2007.
  1. Naicidrac
    Naicidrac TPF Noob!
    Aug 19, 2006
    184
    Hello all,
    I have and LCD and a regular monitor with a ray tube. At home my pictures look one way and then at the work monitor they appear darker. I have not printed them yet, but I was wondering if you guys knew of some way to calibrate a monitor. I rember seeing some wesite that showed you some stuff and if you could see it or something like that, then your monitor was working well. Thanks for the help.
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I have seen those test strips...supposedly, if you can see all the different blocks, your monitor is OK. Well, I've found that's not good enough.
    You can use software like Adobe Gamma but again, still not good enough.
    To really do it properly, you need a hardware device. I have the Colorvision Spyder II and the Express software package. There is also the Pantone Heuey, or somthing like that. These devices actually measure your monitor and create a profile to give you accurate tones and colors.
  3. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    if your used to colour printing and can "see" colours correctly then adobe gamma isn't too bad, I've used it since turning digital and put together many albums without a worry, and I send the shots to be printed at a lab, telling them not to correct any of my files.
    The only time they came back messed up was when the printer autocolour corrected them without reading the notes, this process actually reverses the work you already did. I contacted the lab immediately on receiving the shots and got another batch sent out next day for free. However, if your unused to colour production or photographic practise in general get yourself a hardware calibrator tool as Big M suggests.
  4. TomHuck-wa
    TomHuck-wa TPF Noob!
    Jan 20, 2007
    81
    South central Washington state
    I use the spyder 2, it takes about 5 minutes once a month and does a fine job. It will work on lcd or crt monitors.
  5. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    I use Monaco Optix. Fantastic stuff, but very pricey.
