Monitor/MPIX issues
Discussion in 'Photographic Discussions' started by JIP, Oct 3, 2009.
  1. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    I have a problem, I am not sure if this is the right are to address it bit let me know. I recently got the below images plus several more printed at Mpix. The images (to me) look very rich and colorful and the sky looks almost polrizer blue. When I got the recent prints most of them were washed out and lught and generally not what I see on my monitor. I have a Spyder 3 and use it regularly to calibrate both of my monitors but still the images are washed out. So the question is this, are they washed out or did Mpix screw up??. If they do look washed out does any one have any suggstions on how to properly adjust the density with the Spyder. Thanks anyone in advnce for your help.
    I have not looked at the posted images since before I posted them but originally they looked as I posted good as far as density goes.
    [​IMG]
    [​IMG]
    [​IMG]
  2. schumionbike
    schumionbike TPF Noob!
    Mar 9, 2007
    1,083
    Houston, Texas
    The sky is blue on my screen and my screen is not calibrated :). But yeah, the color of the sky look great.
  3. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,475
    15,209
    USA
    I think you're seeing the result of the wrong working profile being assigned to the images, which is sRGB, and your monitor and computer system are viewing the images in Adobe RGB; in sRGB these images look a bit flat and dull, but in Adobe RGB, which is where you are viewing them, the skies are intense blue and the saturation looks high. But opened in their assigned profile, which is sRGB, they don't have the same punchy look you are seeing on your system.
    MPIX is printing the images as they came in, with sRGB assigned, hence the disappointment.
  4. JIP
    Aug 29, 2006
    3,019
    Pittsburgh PA
    So any suggestion on how to solve the issue with the several hundred images I have already edited in this way. Of course I would also like a suggestion on what to do to fix this for future refrence.
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Well you won't ever match the screen exactly without a viewing box, but also what is the contrast of the screen? When calibrating the software defaults just look at tone response and colour accuracy, and often negate the all important limiting of contrast ratio, since screens will likely have a contrast ratio significantly higher than a print.
    Also MPIX has a fancy talking website, but they also offer very cheap printing services with no gurantee of accuracy. Are these the 19c prints they offer? Our local Rabbit Photo lab still make modifications to the image if you click on the "no touchup" option. I've noticed this in the form of excessive sharpening with large radius (increasing contrast), and an overall lightening of dark parts of the image, which can often have a big effect on a dark image.
    This kind of effect sells prints and I doubt you'd find anything better from any other 19c service. That said if you paid a few dollars for this print it would be good to follow the result up with them.
  6. FrankLamont
    FrankLamont TPF Noob!
    Feb 20, 2009
    556
    They aren't polariser blue to me... blue, but not dark blue per se.
  7. JIP
    Aug 29, 2006
    3,019
    Pittsburgh PA
    I guess I may have overstated that but I did darken them a good bit in CS4 and they came back from MPIX quite a bit lighter. So I guess the main thing to do is going to be to coordinate with Mpix but it is the weekend so I thought I would come here for suggestins first and try and figure out if it is my monitor calibration or some overzealous correcting on the part of Mpix or something else entirely like incorrect color soacing as has been suggested.
  8. KmH
    Apr 9, 2009
    40,733
    5,587
    Iowa
    Check out this Mpix Support page if you haven't already. (Mpix>Support tab>Online Help>How To Prepare Your Images.
    Mpix guarantees their prints if you opt to have them do color correction. If you do the color correction, they don't.
  9. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    Pro-labs over here print from RGB files and will give you profiles for their printers which you assign in PS, cheapies do sRGB and you get back any garbage they want to give you, that's why they are cheap.
  10. KmH
    Apr 9, 2009
    40,733
    5,587
    Iowa
    Yep.
    Mpix offers soft proofing too.
  11. RyanLilly
    RyanLilly No longer a newbie, moving up!
    Aug 27, 2007
    1,478
    8
    St. Louis, Missouri, USofA
    Maybe an incorrect color profile either in your workflow or embedded in the file? Generally my "no Correction" 19ยข prints come out pretty accurate even on a non-calibrated monitor. I would check all of your color settings and get in touch with mpix, There is probably a solution just a couple clicks away.
    off topic; your exif, says that your photos were taken October 01, 2010! So the D700 Does include a Flux capacitor?
  12. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    MPIX will provide profiles. Just ask for them.
    I am cheap and lazy, I simply followed the directions on their webpage using sRGB and clicked off "do not color correct". No problems thus far... maybe I am just lucky.
