Mono pod for HDR?
Discussion in 'Photography Beginners' Forum' started by Nolan, Aug 23, 2009.
  1. Nolan
    Nolan TPF Noob!
    Jun 2, 2009
    246
    Toronto
    Im in the market for a mono pod for my D90. But i have a concern. Can mono pods be used for making HDR photos with out difficulty or negative results? This concern is simply because i haven't and idea how stable mono pods are.
    Thanks for your responses!
  2. Nolan
    Nolan TPF Noob!
    Jun 2, 2009
    246
    Toronto
    any one?
  3. Big Mike
    Dec 16, 2003
    33,831
    1,812
    Edmonton
    Monopods limit movement in the vertical plane (up & down) only. They are more stable than just holding the camera/lens in your hands, but nowhere near as stable as a tripod because a tripod stands on it's own while you are still required to hold a monopod.
    Software might be able to combine shots for HDR etc. from a monopod, but ideally, you should use a tripod for that type of stuff.
  4. chammer
    chammer TPF Noob!
    Jul 30, 2009
    642
    5
    Virginia Beach, VA
    dont think its quite stable enough for an hdr, however, i did just pick up a manfrotto 680b monopod the other day and its fantastic. cant recommend it enough!
  5. Nolan
    Nolan TPF Noob!
    Jun 2, 2009
    246
    Toronto
    Ok thanks.
    I was just considering the monopod because most of my subjects are in nature, so the less wight i have to haul in to the woods or mountains the better. Do know of any good light wight tripods between $150-$200 that would do the trick?
  6. choudhrysaab
    choudhrysaab TPF Noob!
    Jul 11, 2009
    667
    Toronto, Ontario. Canada
    i've been told mono pods are good for "panning" shots but not really for getting multiple shots with different exposures cuz there's a high chance the camera will move from its original place.
  7. tirediron
    Jul 8, 2005
    37,892
    10,923
    Victoria, BC
    You should be able to pick up a set of used Manfrotto 190 legs and a second-hand 488 ball head for that price.
  8. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    Indeed. It's easier with a tripod or monopod to just spin the camera in place and get consistent cylindrical distortion on the final pano; if done hand-holding, if you're in a tight space, things can get a little wacky. But as for HDR it really isn't helpful. You'll need to shoot wider and align the images later, and NO image alignment is ever quite bang-on.
  9. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    Can't go wrong if you buy a monopod + a ball head with a pan trigger
    as you can always just buy tripod legs, since you have a head already...
    You dont need a head for monopods (it has a built in screw fix.) but it allows for more flexibility and height if you add a head to it
    I have a manfrotto 680B with a 486RC2 Mini Ball head
    I dont think the mini is a problem... just smaller
    Next on the agender is Manfroto 190xProB legs possably
    But to answer your question, Yes... Depending on the circumstances, If your shooting > 1/300 with a monopod, You should be good to go
    even a little slower might do (Assuming your using Auto bracketing.)
    But a tripod + wireless trigger is recommended.
  10. McNugget801
    McNugget801 TPF Noob!
    Jul 13, 2009
    388
    43
    I do lots of hiking and landscape shots with plenty of on the trail hand held HDR shots (AEB). - Its a 50/50 shot depending how how still I can hold.... The mono pod would be better then hand held but not better then a real tripod.
  11. CW Jones
    CW Jones TPF Noob!
    Feb 26, 2009
    813
    Connecticut
    Should be fine, the program I use (photomatrix pro) helps align the pictures. I have made HDR by hand holding and they have come out just fine. I even had to lower the camera to change the setting and it came out great haha
  12. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    I am sure it is better than handheld. If the shutter speed is fast enough and shooting wide angle, you maybe able to do so.
    This one is a hand held shot with my body lean against a wall with deep breath.
    [​IMG]
    But of course, tripod with remote shutter is better.
best monopod for hdr
hdr monopod
hdr multiple images & monopods
how to use mono pods
make a mono pod
mono pod for hdr
monopod for hdr
monopod for hdr photography
monopod for hdr shoots
monopod hdr
