Moon Photography?
Discussion in 'Photography Beginners' Forum' started by barfastic, Jul 7, 2009.
  1. barfastic
    barfastic TPF Noob!
    May 18, 2009
    119
    I know there are like 50 billion moon photos on this forum, but i have a great opportunity to get some nice shots tonight (got a 75-300mm lens, tripod and its going to be a full moon followed by a lunar eclipse), and i was looking for some insight on what settings to use.
    from what ive read, people like using low ISO, low f-stop (f/4 or f/8) and setting their exposure time from there.
    Am i heading in the right direction? are there any other bits of information or help you gurus can dish out so i can get a nice shot of it?
    Thanks in advance,
    Mike
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Remember that the mood is lit by direct sunlight, so to properly expose for it, you would set a similar exposure as you would for something lit by midday sunlight. So that is why I've heard a few people recommend starting with the 'sunny 16 rule. F16 with the same number for ISO and shutter speed....ISO 100 and 1/100 (or close to that).
  3. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    You are correct about iso 100
    but wrong about the aperture
    set your camera to Aperture Priority
    set to around f8 - f16
    Set your WB to Daylight
    Set ISO 100
    EV i put to around -1/3 (if you have a canon 450D you go into the menu then custom func. then change the EV stop to 3rds.)
    then frame up and shoot (using spot metering)
    also i took some moon shots the otherday (never followed my rules though lol) with a 75-300mm
    it doesn't get very close tbh
    You need a much longer zoom (between 600 - 1000mm) or a telecovnerter to get the sort of shots you see on here with the Texture intact
  4. barfastic
    barfastic TPF Noob!
    May 18, 2009
    119
    my camera is a sony a350, but what im hoping is to be able to crop and amgnify the image, as its 14MP... i guess ill have to try it out and see! if i cant get an image i like or get it large enough, that gives more of a reason to buy a teleconverter :p
    ok so extra things to set up is spot metering, and exposure compensation, and getting the right white balance.
    any thing else i might need to know?
  5. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
  6. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    I find I have to play around every time I decide to shoot the moon, the same setting never works all the time. I can go from f/11 to f/16 and 1/180 to 1/500 all at ISO 200. That's the beauty of digital, you can fine tune to your hearts content and just pick what looks best when you upload.
  7. astrostu
    astrostu I shoot for the stars
    Aug 1, 2006
    676
    17
    Boulder, CO, USA
  8. HeY iTs ScOTtY
    HeY iTs ScOTtY TPF Noob!
    Jun 29, 2009
    380
    north west indiana
    post what you get when you get it id like to see
  9. barfastic
    barfastic TPF Noob!
    May 18, 2009
    119
    ok so i got some pics, although not as close as i would want.... and the focus is a little off as well. Even though i had a tripod it was EXTREMELY windy and no matter where i set up my rig it would almost always shake a little.... the best result i had was from a handheld... but i havent uploaded it anywhere yet.
    Seems i did need a teleconverter or a lens with a larger zoom factor... :(
  10. tnvol
    tnvol TPF Noob!
    Jun 20, 2009
    224
    Tennessee
    Nice tutorial! This is something I've been trying to do for a while with no real success. Thanks a bunch for the guide!
  11. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Do you have a telescope?
    If you do, you can get a T-Ring for about $10...
    It probably wouldn't be cost effective to buy a telescope if you don't already have one... Although you could get a cheap one for a lot less than a lens of the same length. A lot less.
    It won't be fast, but it will be long.
    EDIT
    Actually, it might be a little faster than I thought.
    A Mead 400mm (f/5) refractor can be had for $270. 900mm Celestron refractor (f/13 - pretty slow) $140.
    There are more...
    That hobby can be even more expensive than photography though, so be careful...lol.
