Moon Picture Need help
Discussion in 'Photography Beginners' Forum' started by Provo, Dec 1, 2009.
  1. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    I need tips on what settings should I be using to get a nice picture of the moon this was my 1st attempt and as you can see it sucks. I wanted to capture a nice clear shot of the moon withought the effect of it looking like a spotlight.
    [​IMG]
    File Info 1
    File: DSC_0003.NEF, DSC_0003.JPG
    Date Created: 12/1/2009 5:28:06 AM
    Date Modified: 12/1/2009 5:28:06 AM
    File Size: 9.82 MB, 2.32 MB
    Image Size: L (4288 x 2848), M (3216 x 2136)
    File Info 2
    Date Shot: 12/1/2009 05:27:20.00
    World Time: UTC-5, DST:OFF
    Image Quality: Compressed RAW (12-bit), Jpeg Fine (8-bit)
    Artist:
    Copyright:
    Image Comment:
    Camera Info
    Device: Nikon D5000
    Lens: VR 18-55mm F/3.5-5.6G
    Focal Length: 18mm
    Focus Mode: Manual
    AF-Area Mode: Single
    VR: OFF
    AF Fine Tune:
    Exposure
    Aperture: F/22
    Shutter Speed: 20s
    Exposure Mode: Aperture Priority
    Exposure Comp.: 0EV
    Exposure Tuning:
    Metering: Matrix
    ISO Sensitivity: ISO 1000
    Flash
    Flash Sync Mode:
    Flash Mode:
    Flash Exposure Comp.:
    Colored Gel Filter:
    Image Settings
    White Balance: Auto, 0, 0
    Color Space: sRGB
    High ISO NR: ON (Normal)
    Long Exposure NR: ON
    Active D-Lighting: Auto
    Image Authentication:
    Vignette Control:
    Auto Distortion Control: OFF
    Picture Control
    Picture Control: [NL] NEUTRAL
    Base:
    Quick Adjust: -
    Sharpening: 2
    Contrast: Active D-Lighting
    Brightness: Active D-Lighting
    Saturation: 0
    Hue: 0
    Filter Effects:
    Toning:
    GPS
    Latitude:
    Longitude:
    Altitude:
    Altitude Reference:
    Heading:
    UTC:
    Map Datum:
  2. CWN
    CWN TPF Noob!
    Nov 18, 2009
    173
    20 second shutter speed and 1000 ISO is your problem.
    The moon is lit by the sun, so it's plenty bright. Try something more like:
    F11
    1/500
    200 ISO
    Adjust shutter speed and/or aperture to your liking.
  3. Stormchase
    Stormchase No longer a newbie, moving up!
    Oct 6, 2009
    1,170
    88
    Phoenix Arizona
    Quicker shutter. To pull detail out of the moon you will loose detail on other things. Most of the time I'm zoomed in to 300mm at no with around 100 and faster shudder speed.
  4. Goontz
    Goontz TPF Noob!
    Jul 17, 2009
    1,275
    Austin/Houston, TX
    Definitely lower your ISO. Try using 200, if not lower, aperture more like f/8-10. Also try zooming in just on the moon and spot metering on it. Do you have another lens with more zoom power? To really see any detail on the moon, you'll want to zoom in on it specifically and 55mm isn't much. Are you also wanting the buildings in the shot or just the moon? I see this was shot at 18mm.
  5. Wolverinepwnes
    Wolverinepwnes TPF Noob!
    Oct 28, 2009
    289
    slow shutter is for objects that are dim, so you keep the shutter open to increase the amount of light that hits the sensor, the moon is plenty bright so you need much faster shutter speed!! its the stars that need slow shutter speeds! good luck
  6. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    As mentioned, the moon is directly lit by the sun....so you'd need about the same exposure as you would need when shooting something in broad daylight. This will give you a better exposure for the moon...but it will render the rest of the scene completely black (or at least very dark).
  7. Provo
    Provo TPF Noob!
    Oct 27, 2009
    934
    20
    Ex Member
    I am planning on trying again tonight if the moon is full again.
  8. KmH
    Apr 9, 2009
    40,553
    5,544
    Iowa
    You might give the search feature a try:
    http://www.thephotoforum.com/forum/beyond-basics/147712-lunar-moon-photography-guide-astrostu.html
    It's full for about 5 minutes tonight, but the day before and the day after are close enough to consider it full.
    Shooting the full Moon results in a fairly flat image because there are no shadows to model surface details. The bright crater Tycho 9lower right quadrant ina camera view of the Moon) is a bug-a-boo because it is several stops brighter then the Mare.
    The best time to see detail in the Moons surface is when the terminator (the day/night line) is well away from the edge of the Moon's disk.
    The ultimate Moon series is 28 images showing each night of a single cycle 28 day (though the day of new Moon is also a tough shot since the side that faces us is very dark save what Earth shine hits it.
  9. jensgt
    jensgt TPF Noob!
    Nov 21, 2009
    242
    16
    Bowie, MD
    [​IMG]
    Just took my first shots of the moon tonight...walked outside and saw how big and bright it was and had to try it! Shutter speed is super high but it seemed to work for me....
    Sony DSLR-A300
    F/5.6
    1/3200
    ISO 200
    300mm
  10. Inst!nct
    Inst!nct TPF Noob!
    Sep 16, 2009
    702
    Troll, Wisconsin
    jengst, since the thread is a bit sidetracked atm, how you liking the sigma?
    Btw, white balance issues on the moon.
    and anime avatar OP, quick shutter speed
  11. Aye-non Oh-non Imus
    Aye-non Oh-non Imus TPF Noob!
    Nov 18, 2007
    516
    23
    One issue only mentioned in passing was your aperature. Have a look at photozone.de or DXO to find your lens's sharpest aperature. You have gotten the star affect on all light sources in the image and that can be attributed to f/22. Set yours to f/5.6 to f/11 (likely f/8) to grab the moon at it's sharpest setting.
    I like your idea of capturing the moon in an environmental setting rather than the usual ball in the sky.
    Keep at it.
  12. thebeatles
    thebeatles TPF Noob!
    Oct 30, 2007
    805
    pennsylvania
    :lmao: I enjoy your honesty.
sony a100 settings for moon picture
