Moon
Sil
Canon sx 60 hs
Canon sx 60 hs
I got one of those. Never tried using it for that. Will have to get the battery charged up and give it a go. They really do work well if stabilization is turned off and on a tripod with a remote.
  • Like
Reactions: Sil
Thank you all for reply...; -) ..
@JC ... Canon sx 60 is good Camera... he needs good light and does his job
That is some magnification.
This is a 500mm lens on a DX body, 750mm FX/FF equivalent. And the moon is smaller than in your pix.
Zombie and Dean...thank for reply...; -)
@ac12 .... in this image no magnification. ... thank for reply...
The Canon SX 60 HS has a 1/2.3 sensor giving a crop factor of 3.9x.
Crop factor - Wikipedia
In other words any magnification provided by the camera lens is then magnified 3.9 more times by the small image circle the lens has to provide for the small image sensor size.
For your camera the specs are 65x Optical zoom, 4x Digital zoom, and 260x Combined Zoom with Optical Image Stabilizer.
So lots of magnification - either in the camera or by post process cropping of the original image.
I did not make any crop ... it's not necessary..... just to frame well
here... all info..
Nome file
Dimensione file 14.2MB
Nome modello fotocamera Canon PowerShot SX60 HS
Data/ora scatto 29/01/2018 22:25:09
Modalità scatto AE programma
My Colors Spento
TV (Velocità otturatore) 1/13
AV (Valore diaframma) 6.5
Lettura luce Spot
Compensazione esposizione -1 2/3
AEB +1 2/3
Sensibilità ISO 100
Obiettivo 3.8 - 247.0mm
Distanza focale 247.0mm
Zoom Digitale Nessuno
Mod. IS Acceso
Dimensione immagine 4608x3456
Qualità immagine RAW
Flash Spento
Bilanc.Bianco Automatico
Modalità AF AF singolo
Parametri
Contrasto Normale
Nitidezza Normale
Saturazione Normale
Colore sRGB
Rid. rumore Standard
Modo scatto Autoscatto
Nome proprietario
Commento
