Moorhen
Discussion in 'Landscape & Cityscape' started by Anubis, Jan 6, 2007.
  1. Anubis
    Anubis TPF Noob!
    Nov 12, 2004
    285
    Sunny Scotland
    My first photograph of a Moorhen. Not the greatest shot in the world, but my first ...sitting outside, very still, in the cold, waiting for ages... type shot. It was taken at full 420mm zoom as they are very timid and I couldn't get any closer than I was.
    Moorhen (56K Beware)
    I've ordered a camouflage "bag" hide, so I should get better images once I can get closer without arousing suspicion.
  2. tpe
    tpe TPF Noob!
    Nov 18, 2005
    964
    12
    Copenhagen Denmark
    Where are you and why are they so timid? Here they will eat food off the end of the lens if you let them, beautiful animals though, it would help the picture if the bird wasnt totally centered and there wernt reeds out of focus in the forground. Something i think helps a lot when taking pictures of animals is a bit anthromoprhic, that is to make sure the subject is comming towards the camera, it makes them look less afraid, undisturbed and natural.
    tim
  3. Anubis
    Anubis TPF Noob!
    Nov 12, 2004
    285
    Sunny Scotland
    I was sitting on the opposite bank of the lake.
    They are very timid here (its a little nature reserve on the edge of the city), if you don't sneak quitely and keep low when approaching the lake (from quite some distance away) they all dissapear into the reeds.
    As I said, i've ordered a camouflaged hide, so hopefully some better shots to come. :)
  4. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    that shot is ok for a first timer :)
    my first time shot of a squirrel at 420 pretty much looks the same ;)
    420mm ,is that a 300mm prime with a 1.4x teleconverter?
  5. Anubis
    Anubis TPF Noob!
    Nov 12, 2004
    285
    Sunny Scotland
    210mm with a 2x teleconverter
  6. Anubis
    Anubis TPF Noob!
    Nov 12, 2004
    285
    Sunny Scotland
    I shot it in RAW, so I can blow up the moorhen bigger but it is a bit too grainy if I do that.
  7. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    well, blowing up the image can be done with jpeg as with raw. no difference there ;)
    as for the grain, does your raw converter have grain reduction? if not, you might want to try neatimage or noise ninja which do a very good job when it comes to noise/grain
  8. Anubis
    Anubis TPF Noob!
    Nov 12, 2004
    285
    Sunny Scotland
    I thought since the RAw file has 4MB than the jpeg there would be more information to blow up and therefor better quality.
    I use Nikon Picture Project to transfer my pictures to the PC from the camera, it also does the RAW->JPEG conversions.
    I'll need to have a look for a grain reduction feature.
  9. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    Not sure about Nikon, but normally when you set your camera to highest JPG quality, loss due to compression will be minimal. You get the same pixel resolution and almost the same image resolution (if not totally the same).
    RAW images are larger, since they store more other information. RAW is 12 bits per R, G and B channel, whereas JPG is only 8 bits. That means when you start manipulating colours and brightness, you have a broader margin before things go wrong and you see artifacts. Also the RAW image is still linear, and the sensor characteristics curve + whitebalance curve have not been applied yet. This is only done in the RAW converter giving you, again , more freedom in manipulation during that conversion.
    yep, i think they have trial versions with some restrictions. so you can test, neatimage pro probably costs around 130 Scottish Pounds or so ;)
  10. Dougie
    Dougie TPF Noob!
    Dec 30, 2006
    131
    West Calder, Scotland
    There's man-made pond outside my work here in Edinburgh. Complete with a Heron, four swans, moorhens, coots, tufted ducks, etc, etc. Not in abundance you understand but plenty of good shots in the making.
  11. Anubis
    Anubis TPF Noob!
    Nov 12, 2004
    285
    Sunny Scotland
    I just bought this jacket :) and I'm still waiting for my hide to arrive.
    So good shots on the way soon I hope!
  12. surge
    surge TPF Noob!
    Dec 1, 2006
    114
    Glasgow, Scotland
    lol
    so much better than those drab pounds stirling
