More B/W converstion questions
Discussion in 'Digital Discussion & Q&A' started by Hair Bear, Sep 21, 2006.
  1. Hair Bear
    Hair Bear TPF Noob!
    Sep 20, 2006
    398
    I can see its been on here before and I have read other sites but all the examples seem very long winded to me.
    I have just been converting colour to B/W in the Image>Mode in Photoshop, then back to RGB same menu
    Then I use levels to adjust how I need, for complicated pics I might have a double copy of the image on layers that i can 'burn' through to reveal a slightly different contrast.
    Thats it! Do i really have to go through all these channel mixing bits? Really?
    Here is an image I took recently on colour film, scanned to CD and I converted it using the above method. It also has a 4/0/-4 setting in the colour levels to give it some sepia rather than the blue it has in RGB
    Is it that off?
    [​IMG]
  2. Rob
    Rob TPF Noob!
    Jan 29, 2005
    6,217
    134
    London
    That's pretty good, the levels are fairly healthy, you've got a good tone on the skin. I'd say the white areas are bordering on slightly overblown, especially the rose/carnation, so I'd be tempted to drop the lightness slightly and boost the contrast a little to give a bit more depth to it. It might be worth as an alternative method (my favourite) trying the following routine:
    Adjust levels and curves to make the image a little too bright but histogrammatically even.
    Apply a red filter at 30% preserving luminosity.
    Apply gradient map
    Desaturate
    Apply warming filter (to give sepia appearance) or use duo-tone
    Rob
  3. Tiberius
    Tiberius TPF Noob!
    Jun 19, 2006
    328
    Michigan, USA
  4. JDP
    JDP TPF Noob!
    Aug 16, 2006
    285
    Minneapolis, MN
    Well, for me, I convert color to black and white in PS CS2 by...
    Converting to lab mode color
    Select lightness channel
    Convert to grayscale
    Set selection to current channel
    Inverse
    New fill layer, solid color, slot color grayscale, gray 100
    New layer, opacity 5%
    Play with curves
    High pass filter, 10px radius
    hard light layer, opacity 30%
    then flatten image.
    Done!
    [​IMG]
    [​IMG]
    [​IMG]
  5. PixelPerfect
    PixelPerfect TPF Noob!
    Sep 23, 2006
    63
    Boston MA
    I was tought to use Channel Mixer in RGB. Use starting point 70
    10
    20
    Check the monochromatic box int he bottom left hang corner.
    I was always tought NEVER to desaturate or just change to grayscale.
    For one it damages your histogram becuase it is just "moving" things around.
    Hope you find this helpful:)
  6. Hair Bear
    Hair Bear TPF Noob!
    Sep 20, 2006
    398
    Maybe the best thing to do would be to try several of the methods here and see what sort of results I get.
    I have to confess there are other pics in that batch that I couldn't convert and get a rich tonal value in b/w.
    Ill take the hardest image and this one and run several methods to see how they work and post back later < v busy at the moment so this may take a few days.
  7. Hair Bear
    Hair Bear TPF Noob!
    Sep 20, 2006
    398
    Tib, I had a look at that link and it was good to see the various ways to convert with examples.
    However, I'm not sure I like the results.
    If you look at the colour pic and the tonal values of the image, I do this by squinting at it < yes crude but as you squint harder you see less range. By squinting you can quickly find the lightest and the darkest area and compair tones.
    The building is darker than the sky IMO but in the end results in B/W its lighter?
  8. Hair Bear
    Hair Bear TPF Noob!
    Sep 20, 2006
    398
    I like these images, the last one has a very nice feel. Very dark in the background but still well lit on the subject and jug.
    I will add your method to one of my images to see what happens
