More dramatic shots?
Discussion in 'Photography Beginners' Forum' started by johnwilliams, Apr 7, 2009.
  1. johnwilliams
    johnwilliams TPF Noob!
    Apr 2, 2009
    16
    How do i get a more dramatic sky/clouds shot? Every time i go taking landscape pictures i find it hard to get a nice looking dramatic sky, they always seem boring and uninteresting. Do people often take one exposure for the sky and another for the landscape and post process them? Are there better settings for a more defined sky?
  2. chadsdphoto
    chadsdphoto TPF Noob!
    Jan 23, 2009
    123
    Pierre, South Dakota
    That would be one way. Another is a circular polarizer. On days when the sky is blue, the polarizer can dramatically darken it, almost to the point of black in certain conditions, but you can control how much. And that will make any puffy white clouds really pop out of the dark areas.
    A graduated nuetral density filter will help a lot of times, also. It darkens part of the photo without affecting the other part.
    You'll need to study up and experiment with either type of filter to get the best results.
  3. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Look into CPL (circular polarizer) filters or GND (graduated neutral density) filters.
  4. johnwilliams
    Apr 2, 2009
    16
    Can i use, or do people use a ND filter and polarizer for some shots?
  5. dcclark
    dcclark TPF Noob!
    Feb 19, 2009
    480
    Houghton, MI
    GND, not ND: the "G" means Graduated: half of the filter is darkened (to absorb light from the bright sky) and the other half is clear (to let in light from the darker ground). That's a very useful tool for landscape photographers.
    I definitely use both together, but be careful of two things. First, polarizers don't play well with wide angle lenses (as often are used for landscapes) -- the sky will be unevenly polarized and result in weird changes in brightness from side to side. Second, stacking filters can cause vignetting due to the thickness of the filters. That's usually easy to crop or clone out (or just leave it for an artsy effect), but you should be aware of the possibility.
    Finally... dramatic clouds are one of those things you do have to wait around for. :) Being in the right place at the right time is a bit of a trick!
  6. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    I guess you could, but you have to remember that both types of filters reduce the amount of light getting to your sensor so you should have the camera on a tripod and be prepared to do a fairly long exposure.
