oldnavy170
- Joined
- Sep 7, 2006
- Messages
- 2,236
- Reaction score
- 0
- Location
- Rochester, New York
- Can others edit my Photos
- Photos OK to edit
What a lucky find!!!!
Are you using only one light?
Also what type of bulb are you using?
Thanks in advance.
i got a shooting table at a thrift store here for $17, and have been trying to put it to good use. after practicing with it on a couple other things around the house, i took these shots of some ornaments i just got.
any comments, critique, or suggestions anyone has would be most appreciated.
The objects are reflective in nature and have quite a few hot spots. Others have also noted that they would benefit from something other than a prone position... perhaps hung up or propped up.
Recomendation:
- light tent or a more diffuse light source, like a 2x2' or 4x4' overhead lightsource to give better illumination.
- a bent wire or a banana hanger to hang the items up so that they can be shown in a more "natural" or "in-use" state
- some tack or clear rubber blocks to prop up the items for those which are not suitable for hanging.
Otherwise, that's a cool table.
Now that I look at it, is the table basically a piece of plastic, over the frame, with some clamps? I could make my own with a sheet of flexible plastic? Or is there something I'm missing.
Anyone remember the link to the guy who had diffusion hoods, with a template, so you could buy foam core board and cut your own?
My goal is to make something VERY portable to take shots on location. Even my $4.98 folding tent from a laundry basket, is a bit much. I started thinking flex plastic and lights with diffusion heads. That way I could pull them out, bend the sheet of plastic, light from two sides and the back/bottom, and I'd be done. No tent needed.
If the part about Daylight balance got lost, you can find 5500 K bulbs at Home Depot and places like that. I haven't had much luck with hardware stores. Some have them, some look at me like "what"?
The reason I keep looking is I want a smaller wattage for the bottom, and more for the sides/top. Also balancing the amount of light when different thicknesses of diffusion material are used.
Sheets are too thick, not enough light gets through. I'm still working on something other than paper, more durable, but that lets more light through.
Silk? Nylon?
The project continues.
Oh by the way, I found another clamp light with a better reflector at Goodwill when I was on the road last week. Had to pay top dollar, $2.98 for it.
So while I ramble. Anyone remember where the site was for building the diffusion head at home? I can't seem to remember what search I used.
