Most of my roll ruined! HELP!
Discussion in 'Film Discussion and Q & A' started by cfeldman10, Jan 19, 2010.
  1. cfeldman10
    cfeldman10 TPF Noob!
    Jan 19, 2010
    39
    Canada
    I posted this is the beginner photography section. Thought I should post here as well.
    Hey guys. So I recently bought a Canon Rebel EOS 1000 to use for my film photography class.
    Today I took two rolls of film to the lab to process for my assignment. My first roll came out pretty nicely. Only one picture didn't turn out.
    However, from my second roll, ONLY 6 PICTURES TURNED OUT!
    Even though I just started taking stills on film, I have shot films (movies) before, so I am pretty confident with my ability to expose.
    Some of the pictures that didn't turn out were taken in a forest. What kills me is that under the same lighting conditions, I had many photos all at f/5.6 with a shutter speed anywhere from 1/90 - 1/1000s. So it couldn't have been that ALL of the photos turned out underexposed!
    Has anyone encountered anything like this before? The photos that did turn out are exposed perfectly. Any idea on what went wrong?
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    what do you mean turned out, really would be more helpful to post a photo .
    there are several equipment issues, film advance is not working properly besides the problem with a sticky shutter.
  3. cfeldman10
    Jan 19, 2010
    39
    Canada
    The entire roll was completely underexposed (aside from the last 6 shots taken).
    The negatives are just blank.
    How is it that the last 6 shots turned out perfectly?
  4. ann
    May 14, 2007
    4,263
    189
    have your camera shutter checked out, as that seems to be an equipment failure
  5. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    That would be my assessment as well. Sounds like your shutter started to slow down for a handfull of shots and then quit.
  6. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    On most cameras, you can open the back to check lens and shutter operation.
    In your case, I'm thinking your film wasn't advancing for most of the roll, and then just magically started to.
  7. henkelphoto
    henkelphoto TPF Noob!
    Mar 10, 2008
    105
    Las Vegas
    Can't be. If that were the case, only the first 6 photos would have anything on them, not the last 6 photos.
  8. cfeldman10
    Jan 19, 2010
    39
    Canada
    Thanks for your help everyone! I showed the negatives to my teacher today (all empty except for like 1/5 of a frame). She said she definitely thinks its a shutter issue.
    I bought my camera off the Henrey's ebay store. I called them and explained the issue, their response was "Would you like a replacement or a refund?"
    haha that was easy.
    I currently have the Canon rebel eos 1000. They can replace it with the eos 500 model. Should I go for it?
  9. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    What does the the strip of negatives look like on the second roll, are the first shots that failed light or dark ?
  10. coreduo
    coreduo TPF Noob!
    May 4, 2009
    329
    Light might have 'seeped' into your darkroom. Happened to me first time.
  11. ToddLange
    ToddLange TPF Noob!
    Mar 29, 2009
    118
    Texas
    also if you didnt roll the film onto the spool correctly it will mess up the film if it is touching other film on the spool when being developed.
  12. RancerDS
    RancerDS TPF Noob!
    Nov 5, 2009
    227
    Wagoner, OK
    Camera Page
    This gives you a fairly decent overview of features between models.
