Mountain Lakes
Discussion in 'Landscape & Cityscape' started by brianT, Apr 24, 2010.
  1. brianT
    brianT TPF Noob!
    Feb 5, 2009
    167
    6
    Vancouver
    Here are some lakes in British Columbia. Any comments or critiques are welcome.
    1. Lindeman Lake
    [​IMG]
    2. Chilliwack Lake
    [​IMG]
    3. Chilliwack Lake
    [​IMG]
    Thanks for looking. There's more photos of these lakes on my website, link in signature.
  2. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    Hmm another place i need to visit!
    Good images :thumbup:... are you using any kind of filters?
  3. brianT
    brianT TPF Noob!
    Feb 5, 2009
    167
    6
    Vancouver
    I use a circular polarizing filter to deal with glare on the water. I've also recently purchased a Cokin graduated neutral density square filter. It only holds back 1 stop of light so it's pretty minimal.
    The polarizer was used on all 3 photos. Generally I use the polarizer on most outdoor scenes. The NDgrad was used on the last 2 photos (in combination with the polarizer). So there's a slight image quality loss with all the filtering, but the Cokin is a cheap filter which doesn't help. The image quality loss is hardly noticeable on web-sized jpegs. Pixel peeping the full size photos there's noticeable differences. But for what is gained in the filtering, the detriments are minimal.
    I plan on getting a Singh-Ray NDgrad as I've heard they're among the best.
  4. Arch
    Jan 21, 2006
    8,487
    102
    locked in the attic
    Yea i use Cookin ND grads, although the ND4 and ND8 are probably the ones i use the most in landscapes. You will loose some detail in stacking them with a Polarizer tho, the best thing is to stagger 2 ND's so that the transition is smoother but also gives you a much darker sky if needed. ;)
    There are better grads out there than Cookin tho, thats true.
  5. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    Your first shot is better than the last two. I do not like the combo of the two filters. It is a beautiful lake for a shoot though.
    Do you have others of the same lake?
  6. Josh220
    Josh220 No longer a newbie, moving up!
    May 23, 2009
    1,730
    83
    California
    I really like #1 but I find myself wanting to see more water and less rocks.
  7. brianT
    brianT TPF Noob!
    Feb 5, 2009
    167
    6
    Vancouver
    [​IMG]
    [​IMG]
  8. cnutco
    cnutco No longer a newbie, moving up!
    Aug 31, 2009
    1,566
    51
    NE GA
    That is what I was thinking. I love the colors in the water.
  9. D-B-J
    D-B-J Been spending a lot of time on here!
    Apr 13, 2010
    9,027
    2,172
    The first one in the second set looks great!
  10. Sachphotography
    Sachphotography TPF Noob!
    Jun 17, 2009
    1,229
    Tulsa, OK
    What f stop you shooting at. Seems like it must be around 5 or 6. The background are not really focused and very soft.... I would shoot at like f/16 or so and try to get more in focus.
    Your Composition is very good and you have a good eye. They are lovely shots.
    Keep on shooting!!
  11. brianT
    brianT TPF Noob!
    Feb 5, 2009
    167
    6
    Vancouver
    Thanks for comments. These are all between f/16 and f/20. And the camera mounted on tripod and I used a cable release. The perceived loss of sharpness is due to resolution downsize and jpeg compression. Usually after I resize an image for web posting I resharpen some areas, but not the entire image as I find too much sharpening doesn't look good.
    The original images are pretty sharp for the lenses and camera used. And believe me, it's a constant struggle to make an image that looks great at full resolution into low resolution for web. Generally I find these wide-angle landscapes lose a lot of punch when down sized.
    I also commonly do focus bracketing where 3 separate images are shot at different focus points (foreground, midground, background) for a completely sharp image if desired. On these images I didn't do any focus bracketing though.
    Also, make sure you view the full resolution version of the images as some browsers downsize images automatically.
  12. carlos91
    carlos91 TPF Noob!
    Mar 16, 2010
    115
    miami
    great stuff
