MPEG1 VS. MPEG2
Discussion in 'Off Topic Chat' started by digitalrightnow, Dec 4, 2006.
  1. digitalrightnow
    digitalrightnow TPF Noob!
    Aug 31, 2006
    52
    What is the difference between MPEG1 and MPEG2? I have just started to really work with my digital camera's recording capabilites, and i am pretty happy with some of the results. However I don't really know what format is best to put on DVD. I know where I live in Canada I have to use NTSC, I'll get this through MPEG2, correct? What should I use? Also I am using two different programs to edit my movies, one saves as WMV files, and I use the other to convert them to MPEG files, but what I tend to stick with is MPEG1 and save them to NTSC, is this acceptable or should I go with them MPEG2 NTSC format? I use MPEG1 and it appears that my movie plays ok, on my PC's DVD player. Could someone give me an idea as to how it would look on a regular DVD player?
  2. markc
    markc TPF Noob!
    Mar 8, 2004
    4,237
    6
    Rochester, NY Velocity: Unknown
    MPEG2 tends to be better for interlaced video, which NTSC is, and at high bit-rates, especially if there is a lot of motion. Use it if you are cutting DVDs or SVCDs. If you are making VCDs, will be displaying only on a computer, or perhaps have a lot of stationary images, then use MPEG1. MPEG1 is also works on a lot of hardware. This is just second-hand knowledge, as I haven't done a lot of video work, so take it with a grain of salt.
