My D90 is Being Picky
Discussion in 'Photography Beginners' Forum' started by AdamBomb, Dec 24, 2008.
  1. AdamBomb
    AdamBomb TPF Noob!
    Nov 14, 2008
    200
    Ann Arbor, MI
    So I don't know exactly WHEN it does it, but sometimes, My D90 wont fire. Its normally in Low light, and I think its because of the AF. If I switch my Lens to M, then it will fire no problem, but if the AF can't focus, it just...wont let me take the picture. It's kind of frustrating, is this how it's supposed to be?
  2. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    yup, if its not in focus it wont fire unless your in manual focus or hold focus lock. Think of it the other way... would you prefer the camera to fire all the time without being in proper focus?... you'd end up with a card full of blurry shots even when your trying to get sharp ones.
  3. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    Agreed, I think of it as a reminder to check focus and such, then it fires with no problem. It is just being helpful.
  4. inTempus
    inTempus TPF Noob!
    Dec 15, 2008
    3,692
    4
    Indiana
    I've never used a D90 but my 40D has a visual indicator that flashes if something is out of whack. If it doesn't fire, I can look and see exactly why in the view finder. I assume the D90 has a similar feature.
  5. CaptBill
    CaptBill TPF Noob!
    Dec 24, 2008
    5
    Lower Slower Delaware
    Yes, the D90 has a little green "In-focus" light in the lower left corner of the viewfinder. If it isn't lit, and you are not in Manual Focus mode, the shutter will not fire.
    If it is having trouble focusing, you may have the focus-assist light turned off (a menu selection), and trying to autofocus in low light. The autofocus sensor needs to be able to see contrast in order to work. No contrast, or very low light: won't work.
  6. ShutterSpeed
    ShutterSpeed TPF Noob!
    Dec 8, 2008
    381
    Teresina, Brazil otherwise known as the End of the
    i learned this lesson when i started doing night photography...sometimes i couldn't get it to fire..and i was like ... WHAT THA!...then i realized, it couldn't find the focus subject
  7. djrichie28
    djrichie28 TPF Noob!
    Jan 24, 2008
    264
    7
    Waterloo, ON
    In most cases the camera won't fire if the auto focus is set to 'Single' until is can finish focusing. It should fire anytime if the auto focus is set to 'Continuous' or, of course, 'manual'
  8. DavidElliot
    DavidElliot TPF Noob!
    Dec 19, 2008
    169
    East Lansing, MI
    really? because i have mine set to continuous and my camera still hunts before it fires and more often than not it has a terribly hard time focusing in low light situations. maybe i have it on the wrong settings...
  9. Domokun
    Domokun TPF Noob!
    Oct 2, 2008
    12
    Plumas Lake, CA
    yeah, my XTi does that too. i'm pretty sure that it means that you're in low light or the subject is not in focus. now i just use manual focusing
  10. fwellers
    fwellers TPF Noob!
    Nov 21, 2008
    441
    6
    Northern VA
    The autofocus section of the manual ( page 54 I believe ) describes this.
    There are like 6 things that can prevent autofocus from focusing. Things like not enough contrast between subject and backround, too much contrast between them, geometric patterns etc...
    I think one way to get around it is to use single point focus area as opposed to the 3d or dynamic area. You can hone in on the subject easier that way.
    Also, AF-C mode ( continuous servo ) will allow the camera to take a shot even if it can't focus. Not sure why you would want to do that though.
