My first c&c - be gentle :)
Discussion in 'Photography Beginners' Forum' started by oxcart, Oct 25, 2009.
  1. oxcart
    oxcart TPF Noob!
    Sep 21, 2009
    42
    UK
    Hi folks,
    Maybe someone can explain how I directly post a flickr pic. In the meantime, the link is below:
    IMG_0073 on Flickr - Photo Sharing!
    I recently got a 30D so this was taken on my first day of playing with it. C&C are welcome.
  2. djrichie28
    djrichie28 TPF Noob!
    Jan 24, 2008
    264
    7
    Waterloo, ON
    Be gentle? Sometimes it helps more effectively if we gave C+C on a direct approach. But I will try. Love the composition. Horizon line is a good spot and straight. The only negative thought about this photo is it seems pretty dark in the foreground. A flash would have helped here. Another suggestion would be to have composed this shot from as close to the ground as possible.
    Still good. Keep going. ;)
  3. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    This man speaks the truth.
    No need to be gentle on this photo, It is good, with the exception of the foreground being too dark, Personally would have increased the temperature to make the image a bit warmer
    it is simply unfortunate about the sky being overcast, this would look great at night I think, if you had a flash to light the foreground and use a long shutter to capture motion in the water and get a purple / orange sky.
  4. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
  5. existence02
    existence02 TPF Noob!
    Aug 7, 2009
    41
    As the others have said no need to be gentle with it. It's a great shot. The need for a brighter foreground has been pointed out. That's the only thing I see "wrong" with the picture. I love the mood of the sky in this shot.
  6. oxcart
    oxcart TPF Noob!
    Sep 21, 2009
    42
    UK
    Unfortunately that was as low as I could get without lying on my stomach. There was a bit of a height difference between the path I was walking on and the start of the pebbles.
    I wasn't really very well prepared; it was an off the cuff shot - no flash or tripod with me. Next time I'm home I'll head down along the same stretch of road and see if I can improve on the first attempt.
  7. oxcart
    oxcart TPF Noob!
    Sep 21, 2009
    42
    UK
  8. oxcart
    oxcart TPF Noob!
    Sep 21, 2009
    42
    UK
    One of the good things about Ireland. Constant bad weather = interesting clouds :)
  9. chammer
    chammer TPF Noob!
    Jul 30, 2009
    642
    5
    Virginia Beach, VA
    i dont think much needs to be said other than what has already been posted. a quick note i would try if you do it again. bring a tripod and try a long exposure. i'd love to see some creamy water surrounding those rocks :D
    other than that, i did notice something and its hard to be 100%, but you can take some test shots of a sky at f/22 or so to find out, but on the left of the picture where the water meets the sky there's a dark spot about an inch to the right. it appears at first glance to be a bit of dust on the sensor due to the shape and nothing else around it having shadows of any kind or it could also be something on the lens itself. :)
  10. oxcart
    oxcart TPF Noob!
    Sep 21, 2009
    42
    UK
    I was messing around today too, but it was starting to get dark. Clocks changed, forgot it would be dark an hour early. This was HDR'd but didn't work so well:
    [​IMG]
    Was expecting a lot more depth in the clouds... I bracketed and shot the pics 2 stops either way. That about right? Or should it be over a bigger range? It was really the clouds I was interested in; the foreground stuff isn't mindblowing. But the clouds were interesting. Pity it didn't come across better.
