My first concert photos. Comments Welcome
Discussion in 'General Gallery' started by NEPats37, Apr 9, 2007.
  1. NEPats37
    NEPats37 TPF Noob!
    Feb 10, 2007
    76
    Rhode Island
    Here is my first attempt at concert photos. It was a challenge because it was very dark and the band requested the flash not aim right at them so I had to bounce off the ceiling. I had my aperture open to either 2 or 1.4 for all of these. my scanner is horrible so some of these look a little grainy. i used a bounce card for some of them but it was so dark in there not enough light bounced off the card.
    any suggestions are welcome.
    thanks
    [​IMG]
    [​IMG]
    [​IMG]
  2. NEPats37
    NEPats37 TPF Noob!
    Feb 10, 2007
    76
    Rhode Island
    bump ....any suggestions?
  3. The_Traveler
    The_Traveler Completely Counter-dependent Supporting Member
    Dec 11, 2006
    18,339
    7,570
    Mid-Atlantic US
    yes, post larger pictures - and the best rather than a lot.
  4. Funky
    Funky TPF Noob!
    Sep 24, 2006
    374
    California
    you cant really get a good solid picture with a scanner, all of them are ok but extreamly washed out. bad lighting eh?
  5. NEPats37
    NEPats37 TPF Noob!
    Feb 10, 2007
    76
    Rhode Island
    better now tough guy?
  6. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    I remember saying not to use that flash :)
    I appreciate though that the light was pretty poor looking.
    You could have gone with a slightly slower shutter speed (to get some motion in the hands) and used 2nd sync flash which would bring in the ambient light and only freeze the subjects at the end of the exposure.
    What sort of shutter speeds were you getting and what speed film did you end up using?
  7. NEPats37
    NEPats37 TPF Noob!
    Feb 10, 2007
    76
    Rhode Island
    the first one was 1/60th,the other 2 were 1/125. i actually did use slow shutter speed on a few (1/30th). but i didnt scan them....ill do that tomorrow. it seems this scanner ruins pictures.
    i used 400 speed film, when i was there though i was curious to see what would happen if a pushed the film. without taking any pictures I bumped it up to 1600 and still the pictures were underexposed.
    next time i do a concert im gonna use my canon with my other canon flash. its way more powerful and easier to use.
    thanks
  8. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    What mode was your camera in? Were those shutter speeds ambient light or using set to use flash as the main light?
  9. NEPats37
    NEPats37 TPF Noob!
    Feb 10, 2007
    76
    Rhode Island
    well 1/125 was the flash sync speed, i tired 1/60th to get more light. its a completely manual flash that I have no user manual for, so it's all trial and error. im gonna use my canon auto flash from now on.
  10. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Light has blasted all the atmosphere from the shots. I'd still say no flash unless you can't. Even then shoot in Av and second curtain synch if you can.
  11. manaheim
    manaheim Jedi Bunnywabbit Staff Member Supporting Member
    Sep 2, 2005
    14,394
    3,262
    Well you don't necessarily have to do NO flash, but a bounce flash here would really help a lot. Check out the harsh shadows in the background against the wall and harsh highlights- thats a dead giveaway of a dead-on-straight-in-the-face flash.
    If you can get a flash with a pivot head and bounce it off a ceiling you should have some much better results. Also in a concert situation you probably have a darker room so turn the flash strength down a bit as well and it should give you a bit moodier of an effect.
    Combine that with some really fast shutter times and you can probably get the cool effect of just the outline of the subject closest to the light source... that's always neat.
  12. NEPats37
    NEPats37 TPF Noob!
    Feb 10, 2007
    76
    Rhode Island
    i actually did use bounce flash on 2 of those. however i had a hard time because i was using my fully manual sunpak. from now on im using my much easier to use canon
