My first HDR shots... C&C please.
Discussion in 'Just For Fun!' started by 03civicdx, Jun 14, 2009.
  1. 03civicdx
    03civicdx TPF Noob!
    Jun 13, 2009
    109
    north carolina
    [​IMG]
    [​IMG]
  2. captainkimo
    captainkimo TPF Noob!
    Apr 26, 2009
    65
    Thanks for sharing. Anyway, here's my take on it. Your subject for both photos are the flowers right? I think the background for both is really distracting. You may consider focusing on your subject more, or use a bigger aperture to blur the background. There's also noticeable noise.
    Cheers!
    Captain Kimo
  3. rbvernon
    rbvernon TPF Noob!
    Jun 15, 2009
    4
    Jeanerette, Louisiana
    Try taking a picture of just the flower its self. I took a couple like that and got many good remarks
  4. musicaleCA
    musicaleCA TPF Noob!
    May 23, 2009
    2,303
    Vancouver, BC
    What ISO did you shoot at? It's imperative in HDR to shoot at the lowest ISO possible, because when you tone-map it you increase just about every aberration in the image: softness, noise, CA, etc.
  5. Mohai
    Mohai TPF Noob!
    Apr 3, 2009
    25
    Good attempt, better than mine, but a little too much noise :)
  6. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    These are horribly overexposed and grainy. The purpose of HDR is to capture a scene with high contrasting areas where every area is properly exposed. It doesn't take 3 images blended to come up with an overexposed image and this image would have had absolutely no need for HDR in the first place.
    Go find a scene that has a High Dynamic Range and capture the 3 or more images for your HDR there.
  7. 03civicdx
    03civicdx TPF Noob!
    Jun 13, 2009
    109
    north carolina
    i will try that next time it was HOT!! out side i didn't take alot of time with it lol
    it was set on auto but i'll try the lower iso setting next time thanks for the advice.
    Thank you
    over exposed? dont look it to me? :confused:
  8. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    :scratch: Well, I can't see any detail at all in the leaves of the white flowers in #2 and parts of the stairs in #1 . Must be my crappy work monitor then.
  9. Sachphotography
    Sachphotography TPF Noob!
    Jun 17, 2009
    1,229
    Tulsa, OK
    Just FYI, HDR is meant for subjects with natural shadows and different levels of light. The pictures you took just look over exposed in direct sunlight. Also there is so much grain in the areas you bumped up its insane.. Try shooting, like the above mentioned, at as low an ISO as possible. Shoot an area that is normally shoot it would result in shadows or dim lighting.
  10. Sachphotography
    Jun 17, 2009
    1,229
    Tulsa, OK
    Quick question? why do you shoot with a Canon as your main camera and a
    Nikon as your backup. A backup usually needs to be the same make as the primary so the lenses can interchange.
    Just curious.
  11. 03civicdx
    03civicdx TPF Noob!
    Jun 13, 2009
    109
    north carolina
    I bought the Nikon first brand new then about a month later I got a deal that i couldn't refuse on the Canon with 6 lenses so Canon it is :lol:.
