My first sports shoot (tennis) how bad did I eff it up?
Discussion in 'Photojournalism & Sports Gallery' started by Vicelord John, Jan 13, 2010.
  1. Vicelord John
    Vicelord John TPF Noob!
    Dec 3, 2009
    359
    Phoenix
    I'm not happy with the results. They look flat to me. They also don't look sharp to me.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    5.
    [​IMG]
    6.
    [​IMG]
  2. Kblc
    Kblc TPF Noob!
    Nov 27, 2009
    16
    Atlanta, GA
    Actually, these shots show some promise, to me. For being your first time trying this, you seem to have pretty good timing. Compositionally I find them interesting as well. I would maybe change a few, like #1) I would pick which third you would like your subject in. The right hand placement is good, but I'm not a fan of him in the center third. That's just me. It is also perhaps the weakest in terms of timing.
    #2) Great timing. The tennis ball is even deformed. The composition works as well. Only complaints of the basics are the pole right behind the racket and the relative lack of separation between the fore- and backgrounds. The two are related in a way, because with a shallower d.o.f., the pole would be less visible.
    #3) This is, to me, a little uninteresting. I don't fully get a sense of action in the shot. Compositionally it's fine but overall, not that great.
    #4) Great shot. A little late on the timing, perhaps, but not by much, but the subject is frozen and has an expression that shows he's really trying. The comp is a little funky. I like it, because you usually see action shots like this cropped tight on the subject and vertical, but this is different, which makes it more interesting. Conversely, it is more standard procedure to crop in tight and you might really get a sense of action then. Keep a little ground beneath his feet in there for context, and the ball as well if possible, but turn the frame vertical and there you go. I'd say try it. Whether or not you like it is up to you.
    #5 & #6) These are pretty much in the same boat for me. They are good shots, framed well technically. They have a decent sense of action in them.
    For the set as a whole: Shallower d.o.f. and maybe try to crop them tighter on the subject. This is more typical of sports shots as the athlete is typically the main focus of the event and you usually want to reflect that in your shot. Again though, these work for me. It just depends on where you want to take it.
    Now for looking soft, I would agree, they are a hair soft, but doing some minor post process sharpening could really help these. Don't go overboard. Subtle is better. Also, bump up the contrast. I would say quite a bit, but it depends, since I love high contrast stuff. Still, higher contrast will make them pop more. The lighting plays a factor here since it looks overcast and that tends to really flatten out a scene.
    Overall, nice job. Keep practicing, it'll come with time.
  3. Vicelord John
    Dec 3, 2009
    359
    Phoenix
    Wow that was really encouraging and teriffic feedback. You showed me what i did wrong while making me feel good about what i did.
    Thank you.
  4. Mulewings~
    Mulewings~ TPF Noob!
    Dec 28, 2009
    433
    SW Wisconsin
    I took shots of a volley ball practice for the first time this fall. After about 250 shots I was starting to be able to follow the game through the lens.
    You have to anticipate the action.
    I love #4 and if these are your first tries ... then I'd say you've done well!
  5. Nyberg
    Nyberg TPF Noob!
    Jan 7, 2010
    57
    Kristianstad, Sweden
    You have done well! I dont know what lens you've used or anything. But try to get closer to the players to get some new angels and more close-up pictures of brackets and stuff. Still, if you are close, you can take those overviewshots you've done here :)
    Looks good, keep on shooting!
  6. Vicelord John
    Dec 3, 2009
    359
    Phoenix
    17-55 f2.8 nikkor
  7. dcmoody23
    dcmoody23 TPF Noob!
    Dec 31, 2009
    316
    I think the shots are excellent.. You got some really good views and motions... I think the only reason why it comes off as "flat" is because the colors are rather bland... Dark clothing against a dark fence cover, faded court, just a lot of grays and fades... I don't know exactly what you'd want to do, I'd imagine a little editing could get your pictures to "pop" right out and look even better. :thumbup:
  8. kajiki
    kajiki TPF Noob!
    Oct 2, 2009
    136
    Japan
    the lighting is quite flat, nice diffuse soft light, most people would die for this light :)
    Shoot your zoom at the 300mm end, which will separate the subject from the background, and add emphasis to the player. Short zoom could be used at the wide end in a remote rig over the player's head, for something a little different.
