My tank
Discussion in 'The Darkroom' started by Actor, Jul 12, 2009.
  1. Actor
    Actor TPF Noob!
    Mar 4, 2007
    421
    Ohio
    My tank is a Phototax Model 20. It has four parts: the tank proper, a funnel, a gasket that goes between the tank and funnel, and a lid with a "pressure release valve."
    It's been years since I've used it. It seems to be light tight only when the lid is on. The funnel does not have any sort of light trap, so it would seem you need to be in total darkness when you add or drain any liquid. Kind of a pain.
    My original tank, which disappeared decades ago, had a light trap in the lid that allowed liquids to be added or drained without opening the tank.
    I'm wondering if I'm missing part of my present tank?
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    how about a "tube" to hold the reels?
  3. Actor
    Actor TPF Noob!
    Mar 4, 2007
    421
    Ohio
    A tube to hold the reels might serve to trap light, particularly if it was black.
    However, since my original post I perceive another problem with its design. I don't see how the thing would ever drain completely without removing the funnel as well as the lid.
    I'm getting too old. I have no specific memory of ever using this thing. But I must have.
  4. compur
    compur Been spending a lot of time on here!
    Mar 6, 2008
    3,041
    509
    L.A.
    That's a pretty obscure tank. If there is a missing part, your chances of
    finding it are remote.
    I recommend simply getting a modern tank such as one by Paterson or
    Jobo, etc. Purchased new, they're are not expensive and can be had for
    peanuts used.
  5. DSPhotography
    DSPhotography TPF Noob!
    Jun 7, 2009
    130
    Augusta, GA
    eBay is a great place for tanks. you can get GOOD steel ones w/ reels for around $10, and GOOD plastic ones for even less.
  6. Actor
    Actor TPF Noob!
    Mar 4, 2007
    421
    Ohio
    I think I can fabricate the missing tube out of PVC, which is chemically non-reactive (and Kodak approved). Unfortunately it seems to only come in white. Dare I paint it? Would black paint react with the chemistry? Or can I get away with leaving it white?
