n00b questions regarding external flash ....
Discussion in 'Photography Beginners' Forum' started by rodman, Feb 4, 2009.
  1. rodman
    rodman TPF Noob!
    Feb 2, 2009
    82
    Garden Grove, CA
    I've never used an external flash .....
    I want to learn about it and the benefits ....
    What advantages does having an external flash have?
    Also I have a Nikon D40 ... what is a good external flash?
  2. Jaszek
    Jaszek No longer a newbie, moving up!
    Oct 7, 2008
    2,177
    31
    Brooklyn, NY
  3. zandman
    zandman TPF Noob!
    Jul 12, 2008
    688
    south chicago
    it can give ur image a 3d effect with the light coming from the side instead of direct up fron = flat image. imo.
  4. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Gives you light in low light situations. If you want to learn more about on-camera flash, read this web site.
    If you want to learn more about off-camera flash, read this web site.
    How much do you want to spend? The Nikon SB-400 Speedlite goes for around $110, the SB-600 goes for around $225 and the SB-900 goes for around $440.
    Other companies make Nikon compatible flashes but quality, power and versatility won't be the same.
  5. Big Mike
    Dec 16, 2003
    33,876
    1,826
    Edmonton
    The biggest advantage of adding an accessory flash is that you can (with most) tilt and swivel the head so that you can bounce the light rather than firing it straight at the subject. The effect of that is that it can give you subject shape and dimension. Direct flash tends to make things look flat.
    Even if you are shooting the flash directly at the subject, having higher up on the camera, further away from the lens will help with things like red eye.
    They are usually a lot more powerful that the built-in flash.
  6. Village Idiot
    Mar 20, 2008
    7,274
    406
