JerryPH
- Joined
- Oct 14, 2007
- Messages
- 6,111
- Reaction score
- 15
- Location
- Montreal, QC, Canada
- Can others edit my Photos
- Photos NOT OK to edit
Since I'm just starting out, I was planning to go with the less expensive SB-600 flash, but now you all have me thinking about buying a used SB-800 instead. Is there anything I should be concerned with about buying a used flash? Are there any parts, like bulbs or capacitors maybe, that would wear out and make the flash useless? Or are these kinds of thing easily replaceable?
Flash tubes are easily replaceable, however if you have no experience with flashes DO NOT TOUCH. A capacitor can contain tens of THOUSANDS of volts even a month after having no batteries in it. If you do not know how to properly drain a cap, have it serviced professionally.
The cap in a SB-600, 800, 900 or a flash like a Vivitar 285HV has enough of a jolt to toss a man 6-7 feet across the room with ease.
I've seen in real life a guy playing with a disposible camera want to take out the flash, and that cap was strong enough that the jolt slammed his arm back and dislocated his shoulder on the spot. He cried like a baby from the pain.
Starting out with off camera flash photography, it is hard to beat the $90 Vivitar 285HV. It is just as strong as a SB-800 but it doesn't have it's range of adjustability nor any support for CLS (which doesn't matter, IMHO). It is my fav workhorse flash when budget is a consideration. I can get 5 Vivitars for the price of one SB-800 or SB-900.
