Dao
Good choice on using a telephoto lens (200mm) and with a wider aperture (F/5.6) to create a creamy background. With the telephoto lens, it gave you more room so that you may not need to be too close to the ground.
The 2nd one is better. And if possible, I will remove the little brown stick next to the flower. (Before taking the photo or PP)
You may also want to play with the curve, add a little more contrast and little saturation. Personally, I will also add a little vignette (just a little).
