ND Grad Filters and when to use it?
Discussion in 'Photography Beginners' Forum' started by hankejp, Feb 19, 2009.
  1. hankejp
    hankejp TPF Noob!
    Aug 24, 2008
    608
    Wausau, Wisconsin
    I tihnk the title says it all. When do you use a ND Grad filter? All the time, just on Sunny days when a fast shutter speed just isn't enough, etc.
    Thanks
  2. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
    You use it in conjunction with your shutterspeed and f-stop to get the results you want..
    An example is the soft flowing waters of a stream or waterfall. You want a shutterspeed of perhaps 1/15 or 1/30, but the day is too bright to stop down the aperture where you want it..... Use a 2,4, or even an 8 stop ND to get the f-stop you want from the lens you are using..
    I wouldn't use one all the time because it just introduces an additional piece of glass into the optics.... but I suppose you could..
  3. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Graduated filters are often used in landscape photography when you want to even out the exposure of a scene. For example, if you are shooting a scene that has some sky and some land. The sky may be a lot brighter than the land so you would have to choose between blowing out the sky or leaving the land in dark shadows.
    With a split or grad filter, you would place the dark part over the bright sky, thus bringing it closer to the light levels of the land...and giving you a better exposure for the overall scene.
    I don't like the idea of round grad filters, because they force you to place your horizon where they are on the filter...usually in the middle. Square/rectangular grad filters allow you to move them over the lens, placing the split where it fits your composition.
    A straight up ND (neutral density) filters is used to eat up some light, so you can do things like getting a longer shutter speed, as mentioned by LarryD.
  4. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
  5. LarryD
    LarryD TPF Noob!
    Feb 6, 2009
    614
    Mojave Desert
    Yep....
    ..I missed the "grad" part of the question....... My answer only pertains to ND filters...........
nd grad for desert photos
