Necessary equipment for upcoming trip?
Discussion in 'Photography Beginners' Forum' started by gentry1242, Oct 23, 2009.
  1. gentry1242
    gentry1242 TPF Noob!
    Oct 22, 2009
    21
    Houston
    I am going to Europe in a couple months, and was curious to find out what would be considered "essential" lenses for the trip.
    What I have: (just got everything 2 months ago)
    Nikon D90
    18-105mm VR Kit lens
    2 8GB Extreme 3 SD cards
    Tamrac Camera Bag with room for camera + lens and 2 extra lenses
    I am a TPF noob and am relatively new to "real" photography in general. I have begun studying how the mechanics of cameras truly work, but am still pretty much in over my head at this point.
    Thus far, my 18-105 lens has handled pretty much everything I have tried to do, except for three issues.
    First, I tried to focus on something closer than about 2 ft where it refused to take the picture. (not really applicable to my trip)
    The second issue occurred at dusk and early night where I was shooting my dog with no flash playing at the park. I first tried the auto settings and after playing with the settings for 30 minutes, could not eliminate the motion blur. (may be a problem if shooting something with action at low light)
    Third, a couple weeks ago while at the football game, I noticed my subjects did not fit the frame well at maximum zoom. (definately an issue if I want to capture something in the distance).
    I am debating on whether to buy a Nikor 70-300mm VR lens for the longer range shots. I have been told that it is a "slow" lens that works best in good lighting, but for the price, you really can't do much better. The camera store said the next step up was around $2,000.
    I would like to make sure that the Nikor 70-300 VR will capture architectural and scenic pictures while I am in Europe in all types of light conditions. I would also like to have the option to take action shots that do not show motion blur. Is this the lens I am stuck with for now, or is there another brand I should consider? What kind of "distance" does the 70-300 provide over my 18-105? Am I expecting too much from one lens?
    Thank you in advance for your help.
  2. decado
    decado TPF Noob!
    Sep 24, 2009
    155
    Crystal, MN
    You might want to get yourself a multi-coated graduated neutral density filter for shots that have bright sky in it and a multi-coated polarizing filter to minimize reflections when it's sunny. Also, you might want more than 16gb of storage, especially if you're shooting raw.
  3. tirediron
    Jul 8, 2005
    40,878
    12,415
    Victoria, BC
    A reach factor of about 3x. The 70-300 is a very good walk-around lens for long shots. It is a bit on the slow side, but you're not likely to use it at night or indoors.
    For close-focusing there's not much you can unless you want to carry around either close-up lenses or extension tubes. Your other issue sounds very much like motion blur resulting from too little light for reasonable shutter speeds.
  4. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    I am going to say, that for general travel I like my 18-200. I only own this lens to travel with and I have always been happy. I do tend to cary a few filters for it and always bring a Tripod.
  5. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    For me, 2 x 8GB cards would likely not be enough for a trip to europe (unless you are also bringing a laptop or other device to d/l your images as you go along). I would also suggest bringing at least one spare battery.
  6. gentry1242
    Oct 22, 2009
    21
    Houston
    But the consensus is that a 70-300 vr would suit my needs?
  7. syphlix
    syphlix TPF Noob!
    Jul 23, 2009
    687
    NYC
    shrug... personally i'd prefer a wide lens to a tele for a trip like that...
  8. gentry1242
    Oct 22, 2009
    21
    Houston
    I am planning on buying at least 32 more gb an I do have a spare battery.
    Also, can anyone recomend a tripod that is compact and lightweight?
  9. icassell
    Jun 7, 2008
    9,900
    15
    Arizona
    What do you like to shoot? I was in Italy a year ago and brought a few lenses. Most used (> 80% of the time) was the same one that I use as a walkaround here in the states -- my Tamron 17-50mm f/2.8. I also brought my Sigma 50-150mm f/2.8 and a 1.4X TC. I rarely wished I had brought something longer.
  10. TJ K
    TJ K No longer a newbie, moving up!
    Sep 9, 2008
    2,093
    Sunny South Florida
    Whats your price range for that tripod 300, 800?
  11. gentry1242
    Oct 22, 2009
    21
    Houston
    What wide angle lens do you recommend? I have never actually used a wide angle lens. I always just zoomed out to frame my subject and then cropped the photo. Would a wide angle lens create a panoramic style photo?
  12. gentry1242
    Oct 22, 2009
    21
    Houston
    I am not sure on the budget. I was planning on just using walls or benches to brace myself. I do no want something that is cumbersome. If I had to guess, I would rather spend more $ on glass, so less expensive is probably better for me.
