Need a cheap Macro lens. Under $100
Discussion in 'Photography Equipment & Products' started by sj022698, Nov 15, 2007.
  1. sj022698
    sj022698 TPF Noob!
    Sep 12, 2007
    61
    Title pretty much says it all. Doesn't have to be the best but just something to learn with. I'm not spending more. I have a canon EOS Rebel.
    Would love all suggestions. I have a Canon 55-200 mm f/4.5-5.6 II USM EF Lens
    that I thought about selling or trading to get a new macro
    Thanks!
  2. soylentgreen
    soylentgreen TPF Noob!
    Feb 27, 2007
    735
    Miami, FL
    Look at the EF 50mm f/2.5 Macro. It's around $200 though. Only true macro lens I can think of in that price range. You can also try close-up filters or extension tubes in the meantime if you do not have the cash for a new lens. Really depends on the image quality you want and how close you want to zoom in.
  3. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    $100?
    good luck, because pretty much any actual lens isn't gonna happen at that kind of a price, that's basicly the EF 50mm f/1.8 (which is actually damn good for $75) and the 18-55 kit (which is still over $100)
  4. sj022698
    sj022698 TPF Noob!
    Sep 12, 2007
    61
    I have the 18-55. I can't get close enough. What about a used tamron or sigma? What "mm" should I look for in true Macro lens?
  5. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    reversal ring?
  6. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    I am thinking 50mm 1.8 and extension tube? That is about all I can think of for $100 that will give any kind of quality at all
  7. TheOtherBob
    TheOtherBob TPF Noob!
    Mar 27, 2007
    289
    UWS, NY, NY
    You know, I used to do pretty good macro shots with the 50mm 1.8 (now use the 100mm 2.8). The nifty fifty isn't actually all that bad at it -- it's not as close-focusing as it really needs to be to be "macro," but I got some great close flower shots. That might be one (or even the only) way to go for $100. Depending on your use, maybe it won't work for you -- but I was happy with it.
  8. sj022698
    sj022698 TPF Noob!
    Sep 12, 2007
    61
    Well, I basically can get to the glass and it's 30" deep. What about $200 ??? I need to get pretty close.
  9. WolfSpring
    WolfSpring TPF Noob!
    Oct 11, 2007
    159
    shoot through a magnifying glass? J/K I don't know about canon, but a friend and I were looking at macro's for Nikon and all the good ones are upwards of 350+.
  10. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    The reversal ring and extention tubes both will get you there. As for the quality, well... you get what you pay for.
  11. sabbath999
    Apr 11, 2007
    2,700
    68
    Missouri
    Well, if you are talking $200 that is a whole different kettle of fish, and I have a lens that will answer (within its obvious limitations)
    Check out the Tamron 70-300 LD DI II (clicky)
    What it is:
    Sharp
    Light
    Inexpensive (in the $100-169 range generally, depending on new or used)
    A really excellent telephoto for the money, longer than what you already have
    Sharp
    Macro 1:2 that actually works very well (keeping in mind it is a 1:2 macro on a cheap telephoto, and not an actual macro lens)
    Sharp (although I may have mentioned that before)
    What it is not:
    Fast (it is, indeed, quite slow)
    Fancy
    Metal
    Quick to autofocus
    I have this lens, and have shot 10,000+ pictures with it. Is it the best lens out there? HEAVENS NO. Is it the best $150ish 70-300 zoom with a 1:2 macro that I have seen? Absolutely without a doubt.
    It also has the advantage of adding 100mm to the end of the range of lenses you already own, and I can absolutely recommend one without any hesitation.
  12. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    extension tubes will work well with your lens. And since there is nothing but air in extension tubes, the quality of your lens will remain the same. When I used them, I had Kenkos. They allowed connections for the aperture and focus. I never use mine anymore since I bought dedicated macro lens.
