Need a new lens, Telephoto maybe?
Discussion in 'Photography Beginners' Forum' started by Corbin Lane, May 25, 2008.
  1. Corbin Lane
    Corbin Lane TPF Noob!
    Oct 7, 2007
    221
    Columbia, Missouri
    Well, I've been using a Sigma 70-300mm with my XTi. It works wonders but I want something with more zoom. So what are your recommendations for lenses. I don't want to spend 1000's of dollars though. I think my max price is 500.00.
    I will be using this for sports photography.
  2. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    I would say that you're probably out of luck. If you're going to be shooting sports, that means you need fast glass; fast=expensive. Even on the used market a decent f4 400mm is going to run you north of $1000, and an f2.8 300 or larger, well, you may as well put your first-born on the auction block.
  3. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Well its not really going to be practical to get something longer than you have if you want to stay under 500 and still have decent IQ
    I think you should look at something like the sigma 70-200mm f/2.8. It has a little less range but it is alot faster which helps alot for sports
  4. Corbin Lane
    Oct 7, 2007
    221
    Columbia, Missouri
    Yeah, That or a kidney on the black market.
    Thanks for the help everyone.
  5. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    hmm if you can afford something like a canon 70-200mm L USM f2.8 lens then you can use that with a 1.4 and 2* teleconverter to get more length out of it if you need to.
    There is also and IS version of this lens (image stabalization) but that is a little more in cost
    ps I don't know US prices so can't help much there - sorry
  6. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Also look at the 70-200mm f/4 L with or without IS
  7. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    Well with the Sigma 70-200 you can still use a teleconverter, I believe.
  8. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    ^^^^^correct
  9. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    Yes, but you also double your (assuming you use a 2x teleconverter) minimum apeture...
  10. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    Its also important to note that the canon teleconverters only work with canon L lenses (the white ones ;)) due to the physical construction of them which means that they will not conect to other lenses (there might be a few where they will work, but the majority don't)
    So if you are after the sigma lens you will have to get sigma teleconverters
  11. seabug
    seabug TPF Noob!
    May 19, 2008
    28
    Winnipeg
    Hi, if you are shooting sports outdoors you can buy a teleconverter 1.4 or 2x to extend the reach of your zoom by those multiplication factors. They do cut out a stop or 2 of light. There are longer telephotos but they usually come at a higher price.
  12. seabug
    seabug TPF Noob!
    May 19, 2008
    28
    Winnipeg
    I wanted to add that I got a tamron teleconverter that fits several of my canon lenses, I think they also fit sigma lenses.
