Need Advice: Bent Rewind Knob Shaft ( Canon AE-1 )
Discussion in 'Photography Equipment & Products' started by MadisonWI, Jan 18, 2007.
  1. MadisonWI
    MadisonWI TPF Noob!
    Jan 8, 2006
    70
    I just bought a really filthy Canon AE-1 cheap on Ebay, and after a good cleaning and light seal/bumper replacement, it looks really really great.
    However, the rewind knob shaft is bent ... I think. When the camera back is open, the shaft no longer runs paralell to the side of the camera. Also, the rewind 'knob' top itself (the piece CONTAINING the little flip-out crank) no longer lays flush on top of the camera. So either the shaft is bent, or the area of the camera holding the rewind-shaft/knob mechanism has been damaged and no longer holds it properly. I can't seem to tell yet.
    When I put an empty film cartridge in the camera, the fork of the rewind shaft WILL drop into the film canister, but when I turn the rewind knob the film canister moves around a bit because of the 'bent' shaft.
    I think the camera will still be fully functional, but I'm worried that the film will be damaged/scratched when I rewind it.
    Anybody know if I'll run into problems? Or of any ways to fix this, or similar stories?
    OR should I just get rid of the thing (not the best choice.)
    THANKS
  2. jwkwd
    jwkwd TPF Noob!
    Oct 26, 2005
    630
    Western N.Y.
    I would just run a roll of film through it and see if there are any light leaks as a result of a bent shaft. Also, as a result of the film, you would see if it rewound OK. Some of my cameras are pretty banged up, including one as you described, frankly I don't care, they work and rewind without problems.
  3. ksmattfish
    Aug 25, 2003
    7,019
    34
    Lawrence, KS
    Yeah, I'd be more worried about this, and potential film tension problems, than scratching the film.
canon ae 1 rewind crank
canon ae-1 rewind knob
canon ae-1 rewind knob replace
canon ae1 program rewind knob
canon ae1 rewind button
cant rewind film canon ae- 1
problems when replacing film canon ae 1
rewind crank canon ae 1 problem
rewind fork function of a camera
what is the function of rewind fork in the camere
