Need advice on shooting headshots.
Discussion in 'Photography Beginners' Forum' started by anubis404, Mar 17, 2009.
  1. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    I have recently been asked to do headshots for a friend who cannot afford a professional but needs headshots for her resume to be accepted into a professional musical. I have no headshot experience, and help would be appreciated.
    First off, what poses should I use? Can anyone provide a webpage that has information on posing?
    Second of all, which lens should I use? I'm debating between my 50mm F1.8 and my 80-200 F2.8. The 80-200 is better optically, but the 50mm is faster and just the right focal lenght.
    As for lighting, I have a DIY reflector. Where should I position it for optimum lighting? Any other advice would be appreciated.
  2. AlexColeman
    AlexColeman TPF Noob!
    Dec 13, 2008
    1,732
    I would look at pro examples, then imitate them.
  3. anubis404
    anubis404 TPF Noob!
    Apr 5, 2008
    955
    Thanks for the advice. Any thoughs on the placement of the reflector?
  4. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    headshots 101 - The Purpose of Headshots101.com
    They go into a lot of detail there. They don't really go over gear/lighting at all though - just posing and "the rules".
    This website is designed to help an actor shop for a photographer - know what to look for and all that. Still good information for you to have, they just explain everything from the other side of the camera.
    I would actually go with the longer lens and just set up farther away... (Especially if it's the better lens anyway.)
    The 50 being faster will not matter at all - I don't think you're going to want to shoot this at f/1.8 (I would think maybe f/4 or f/5.6).
    I'm sure there are a few people on here that do this for a living, hopefully some of them will jump in here and give some better advice.
  5. bdavis
    bdavis TPF Noob!
    Jan 14, 2009
    784
    Iowa
    I would use the 80-200, its better optically and the telephoto length is more flattering for portraits. Anything from 85-135mm should be good. As for lighting. Sit them close to a window receiving indirect natural light, then use a reflector on the opposite side to bounce light back onto the shadowed part of their face. This almost always gives a nice natural effect and looks professional.
  6. blurryiris
    blurryiris TPF Noob!
    Mar 18, 2009
    21
    Eugene, Oregon
    I AGREE - window light if you can pull it off IS the light of choice. Shooting wedding for years I learned that clients always preferred window light portraits. It's worth your time and effort to scout out a window where you can do your portraits. I went to home depot and snagged some plastic sprinkler pipe and made my own reflector frames. That way I could make really large reflectors for next to nothing. I would make the frame then I would head to the fabric store to find some reflective material. I even made some larger ones and used them as backgrounds. And since you can pick out the fabric you can have some really cool looking backgrounds.
    _______________________________________
    http://www.digitalcameratracker.com
    http://www.ecardsphotography.com
  7. bigtwinky
    bigtwinky No longer a newbie, moving up!
    Oct 6, 2008
    4,820
    285
    Montreal
    Unless you are on a tight schedule, use both lenses :)
  8. bdavis
    bdavis TPF Noob!
    Jan 14, 2009
    784
    Iowa
    Another thing I heard of using as a background is a shower curtain. They're cheap and can be quite effective if you find a nice solid color or simple pattern.
  9. webshow1
    webshow1 TPF Noob!
    Nov 5, 2011
    CA
  10. MTVision
    MTVision Been spending a lot of time on here!
    Aug 1, 2011
    3,008
    527
    Vermont, US
    Did you check the date? This thread was started in 2009!
