Need feedback - pictures at White Sands, NM
Discussion in 'Photography Beginners' Forum' started by kowalczyk86, Aug 6, 2010.
  1. kowalczyk86
    kowalczyk86 TPF Noob!
    Aug 6, 2010
    13
    Holloman AFB, NM
    New to photography. I took these with a Rebel T1i. The landscape pictures are terrible (dark blue colored) - I think I may have had to slow down the shutter a bit to bring in more light...? The white sands pictures that came out looking good, only did because the sun was shining brighter.
    Any feedback is appreciated - some of the pictures of my daughter came out nice (to my standards I guess)..
    Still trying to figure out whether its best to use Tv, Av, completely manual, etc. I read the manual, but seems like I get confused when I am taking pictures - can't quit remember what everything does.
    Shawn
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. tirediron
    Jul 8, 2005
    41,108
    12,493
    Victoria, BC
    The main issue I see with these is exposure. You were dealing with some fairly complex exposure situations and unfortunately, your camera's light meter isn't terribly bright; it gets confused easily, and knowing how to deal with such situations is what separtes the photographer from the snap-shotter.
    There is no 'best mode'. The one to use is the one that will get you the result you want. If you're shooting sports action, you'll likely want shutter-priority/Tv to freeze or control movement.
    For portraits and landscapes, Aperture Priority/Av is generally preferable as it allows you to control the degree of focus of the background.
    The strong blue cast in your imags is a combination of two things: One is the use of auto-white balance not selecting the ideal temperature and second is exposure. Using #3 as an example you have a very bright area in the sky and where the sun is rising. This is 'confusing' your meter resulting in underexposed, blue sand.
    My first suggestion would be to read, and then re-read your camera's manual. Once you've done that, head to your local library and pick up some general photography books. Even if they're older, no matter. Exposure theory hasn't changed.
    Keep practicing!
  3. kowalczyk86
    Aug 6, 2010
    13
    Holloman AFB, NM
    Sounds good - thank you for taking the time to give me some feedback - it is much appreciated.
    Shawn
  4. MrBarney
    MrBarney TPF Noob!
    Jun 7, 2010
    202
    UK
    tirediron has covered it all. I just thought I'd have a go at correcting some of that blue cast. I hope you don't mind.
    edit: I seem to have introduced a good deal of digital noise. :meh:
    [​IMG]
  5. PerfectlyFlawed
    PerfectlyFlawed TPF Noob!
    Feb 2, 2010
    2,408
    19
    Tempe, Arizona
  6. subscuck
    subscuck No longer a newbie, moving up!
    Jun 26, 2010
    1,431
    191
    Illinois, where even the dead get to vote
    A little Post Processing can save a lot of pics, unfortunately, not all, tho. Taking sunrise/sunset pics is a tough nut to crack without HDR. There is far more dynamic range then a digi cam can handle. In evaluative metering, the sun looks like a super nova to your meter, and to properly expose for it, everything else will be under exposed. Expose for the fore ground, and the sun will be over exposed to the point of being completely blown.
    Here's an edit I did on your daughter(beautiful little girl, btw), to show you how a WB correction in camera RAW and a small curves adjustment can give you the pic you saw thru the view finder. Mr. Barney's may be a little better.
    I was in the Air Force from '84-'88 at the now decommissioned K.I. Sawyer AFB in Michigan.
    [​IMG]
  7. j-digg
    j-digg TPF Noob!
    Jan 3, 2009
    476
    15
    Minne-snow-ta
    I personally like this edit, just may need a touch more contrast to deepen the darks some, mainly in the eyes.
    Also you want to watch the horizon line in the viewfinder, and be sure to keep it as close to level as possible ( for those that you dont want tilt to, generally, i.e. landscapes ) its off in a few of them. You can correct it in post but its much easier to do in camera.
  8. reznap
    reznap No longer a newbie, moving up!
    Feb 2, 2010
    2,410
    64
    Ohio
    This is where I'd go with the processing:
    [​IMG]
    The image quality got wrecked in the edit a bit, but I did this only as an example.
    Beautiful location, nice shots.
  9. BuS_RiDeR
    BuS_RiDeR No longer a newbie, moving up!
    Oct 29, 2009
    2,356
    83
    Riverview, New Brunswick, Canada.
    She is very cute...
    I was thinking,,, if your going to put her in the center of the frame... maybe a vertical framing or a 1:1 crop like.... (I also spent 20 seconds in PP to adjust the white balance... not perfect but it shows what a few extra seconds can do...)
    [​IMG]
  10. kowalczyk86
    Aug 6, 2010
    13
    Holloman AFB, NM
    That looks great - did you use photoshop? I have CS4, but I am only a novice at that as well....
  11. kowalczyk86
    Aug 6, 2010
    13
    Holloman AFB, NM
    I think my step-dad was stationed there... Do you know any Pfiesters?
  12. kowalczyk86
    Aug 6, 2010
    13
    Holloman AFB, NM
    I know what you mean about the horizon line... A lot of the pics that I took I had to somewhat chase my (2 1/2 year old) daughter through the sand to get a natural picture - she wasn't "posing" in any of the pictures, so that made it a bit more interesting..
