Need help buying camera
Discussion in 'Photography Beginners' Forum' started by coasterpics, Aug 12, 2007.
  1. coasterpics
    coasterpics TPF Noob!
    Aug 10, 2007
    Hi,
    I need some help with buying a digital camera.
    -I want one that i can change the shutter speed and other features like that.
    -It will be basically for theme park phototography and casual use.
    -I want it to have a good picture.
    My budget is under 450.00 Aud. (about 378.00 Usd)
    thanks for you help.:D
  2. The Phototron
    The Phototron TPF Noob!
    Jun 26, 2007
    948
    Save your penny, nickel, and dimes.
  3. WDodd
    WDodd TPF Noob!
    Feb 20, 2007
    899
    Amherst (Cleveland), Ohio
    There are a ton of threads about this.
    With that budget you will have a wide range of P&S to choose from, all of which should allow you to change your shutter speed and "other features."
    Good luck and welcome to the forum.
  4. spyder
    spyder TPF Noob!
    Jun 13, 2007
    55
    you can change those settings on pretty much every camera, but to get good pics, you may want to save up to around 550 and get a nikon d40 or used d50
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Noooo far from it. The vast majority on the market you have near to no control. I assume you want to keep your hobby small and snapshotty so I won't recommend stepping into the SLR market with a D40.
    You can find "SLR like" cameras from Fujifilm Olympus and others. The only really nicely adjustable cameras I have used is some high-end Olympus P&S cameras (namely the ones with the 10x optical zoom), and the Canon Powershot series which I like a bit more.
    Generally the image quality under reasonably good light is fantastic even on these little point and shoots, it is only indoors at night if you don't use a flash that you start getting noise creep into the pictures.
