Need help from a Canon 350D user
Discussion in 'Digital Discussion & Q&A' started by Josh66, Jan 13, 2008.
  1. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    My LCD is broken and I need to clean my sensor... (I will send my camera in for repair eventually...)
    Could someone please tell me exactly what buttons I need to push to turn cleaning mode on?
    (Everything works, I just can't see the menu...)
    I thought about putting it into Bulb and doing it that way...but it seems too risky.
  2. Antarctican
    Antarctican No longer a newbie, moving up!
    Jan 10, 2006
    24,892
    75
    The Great White North
    I always understood the 350D didn't have an automatic sensor cleaner. If you access the manual online, page 39-40 speaks of how to lock up the mirror and then use a rubber blower to blow away dust on the surface of the sensor.
  3. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Exactly (but it opens the shutter too, not just the mirror), but since I can't see anything on the LCD I need step by step directions on what buttons to push to get there in the menu.
  4. Antarctican
    Jan 10, 2006
    24,892
    75
  5. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    I have the paper copy here (didn't think to check there, I didn't think it would have pictures of the menu. Page numbers are the same...btw).
    To access cleaning mode I need to:
    1. Push "Menu"
    2. Push "Right" 4 times (or push "Left" 1 time)
    3. Push "Down" 6 times
    4. Push "Set"
    5. Push "Set" again
    I'm not sure about step 5... I don't know if the "OK" or the "Cancel" button will be highlighted by default. I think it'll be the "OK" button, but I'm not sure.
    ......I just tried the above list, it didn't work so I started pushing buttons and it went into cleaning mode. I forgot what buttons I pushed though. I'll figure this out soon...
  6. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    OK, I got it. Just in case anyone else runs into the same problem here's the steps:
    1. Push "Menu"
    2. Push "Right" 4 times, OR push "Left" 1 time (both ways get you to the same place)
    4. Push "Set"
    5. Push "Right" 1 time (pushing "Left" probably works too, but I pushed "Right"...)
    6. Push "Set"
