Need Help Photos Inside
Discussion in 'Photography Beginners' Forum' started by BoxPhotographer, Dec 1, 2009.
  1. BoxPhotographer
    BoxPhotographer TPF Noob!
    Jun 23, 2009
    101
    Ontario, Canada
    I just bought a Nikkor 50mm 1.4 lens and I'm not getting the shots I want. I think I have the wrong settings. What setting should I be using, cause these photo's are obviously not sharp what so ever. I do have a SB 600 flash with a flash cord. If need to use it, what do you guys think it should be set at looking at these photo? What correction gel might I have to use? I am going back to shoot more tomorrow so please reply quick! None of these photo's have been edited. I'm using a Nikon D80/.
    [​IMG]
    Why are these so over exposed? It seem somewhat dark. Settings were F1.8 ISO 100, 1/15.
    2.[​IMG]
    Settings were F2.5, ISO 160, 1/13.
    [​IMG]
    Settings were F1.8, ISO 160, 1/40.
    4.[​IMG]
    Extremely over exposed, but why? F.18, ISO 160, 1/50.
    5.[​IMG]
    Dark shadows on her face. Should I use a flash? If so where should it be pointed? Settings were, F1.4, ISO1 160, 1/40.
    6. [​IMG]
    This one was out of focus. F1.4, ISO 160, 1/40.
  2. thebeatles
    thebeatles TPF Noob!
    Oct 30, 2007
    805
    pennsylvania
    Maybe bump up the ISO a but and focus manually?
  3. fstop
    fstop TPF Noob!
    Sep 29, 2009
    46
    USA
    Your not going to get away with ISO 100/hand held in those lighting conditions. Subject and/or you are moving in those shots. Bump the ISO up to at least 400 and give it a shot (most likely 800). Experiment but 5 & 6 could probably use some bounce flash. For the theatre shots, I'd mess more with ISO and try to get away without the flash.
  4. Jeni
    Jeni TPF Noob!
    Nov 21, 2009
    43
    Florida
    I'm no pro. But if I was in your shoes I would be using a faster shutter speed because they all look blurry to me, none of them are sharp. And therefore a higher ISO.
  5. BoxPhotographer
    Jun 23, 2009
    101
    Ontario, Canada
    Any other tips?
    Help is extremely appreciated!!!
  6. RancerDS
    RancerDS TPF Noob!
    Nov 5, 2009
    227
    Wagoner, OK
    Looks like everyone covered the basics. Try to get additional light sources set up for the stage or use a strong flash with diffuser?
  7. fiveoboy01
    fiveoboy01 TPF Noob!
    Dec 28, 2008
    684
    Waunakee, WI
    What mode are you shooting in? Manual, or Aperture/Shutter Priority?
  8. BoxPhotographer
    Jun 23, 2009
    101
    Ontario, Canada
    Mostly manul, sometimes Aperture priority mode.
  9. CWN
    CWN TPF Noob!
    Nov 18, 2009
    173
    With a D80 and no flash you'll replace blur with noise because you'll need to shoot at around 800 ISO minimum from what I can see. The good news is you can fix a lot of the noise with software, but you can't fix blur.
  10. BoxPhotographer
    Jun 23, 2009
    101
    Ontario, Canada
    If I where to use flash, where should I point it?
    I do also have the Lumiquest Ultrasoft.
  11. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,509
    15,225
    USA
    The first shot is a *classic* example of spotlighted performers in front of a dark stage curtain; the light meter sees 90 percent black curtain; the same thing with the girl in shot 4. With the ISO set to 100, and the lens nearly wide-open at f/1.8 in the first shot, the light meter determines that a slow exposure of 1/15 second is appropriate. Spotlighted performers on stage, a classic old-school method would tell you that the light meter reading will tend to OVER-expose, and that a Minus exposure of -2.0 to -3.0 stops will give a more appropriate exposure for the spot-lighted subjects in frames 1 and 4.
    The indoor shots of the two teenagers, in frames were both exposed at ISO 160 at f/1.4, with slow shutter speeds of 1/40- second. The boy has motion blur,and is a bit out of focus.
    The major issue is that you need to boost the ISO much higher--to 640 or 800 or so. For the on-stage shots with spotlighting or strong flood lighting, keep in mind that the subjects will easily be illuminated by light that is 2 or 3 or even as much as six f/stops brighter than non-illuminated areas off stage. For the behind-the-scenes stuff, a touch of flash would be helpful.
    Keep in mind--the D80 is/was noted for its tendency to meter "hot",and this classic stage/dark curtain situation is easily tamed by shooting at what the meter indicates is quite "under-exposed". Good luck. Use the LCD to review to help you get dialed in while at the event.
  12. BoxPhotographer
    Jun 23, 2009
    101
    Ontario, Canada
    thanks!
