Need Help With A Ricohflex TLR
Discussion in 'Medium Format & Large Format' started by BTilson, Apr 4, 2009.
  1. BTilson
    BTilson TPF Noob!
    Aug 12, 2008
    467
    Western NC, USA
    Hello everyone, I recently came across a nice Ricohflex TLR camera. It looks to still be in pretty much pristine condition, and as far as I can tell, everything on it still works fine. I do have a couple of questions though. Here is the camera:
    [​IMG]
    My first question, I've figured out what all the little levers and stuff do, except for this one, the one labeled X M. Any ideas?
    [​IMG]
    Lastly, and this is the biggie, can anyone guide me on EXACTLY how to load film in this thing? I bought a couple of rolls of 120 today (Kodak Tmax 100, and Ilford Delta 100) and I don't want to risk destroying the film through improper loading. Here is the interior of the camera, if anyone can be so kind as to give me some very specific info!
    [​IMG]
    I can see how it should work, but it looks to me like a spool or something must be missing... Maybe I am wrong?
    Any help is greatly appreciated, thanks!
  2. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    5,557
    713
    Woodbridge, Ontario, Canada
    I believe X and M have to do with Flash Sync ... I think.
    The Film you purchased will be on a reel (that is why you only see one in the camera).
    The new Film goes in the bottom ... then you pull the film leader up and into the top leader. Wind the film a little.
    Close back ... wind film until the Arrow mark lines up in window.
  3. dxqcanada
    Dec 4, 2008
    5,557
    713
  4. compur
    compur No longer a newbie, moving up!
    Mar 6, 2008
    2,738
    406
    L.A.
    M & X are flash sync modes.
    X = electronic flash
    M = flashbulbs
  5. BTilson
    BTilson TPF Noob!
    Aug 12, 2008
    467
    Western NC, USA
    Upon reading that link and further looking at the camera, I think it is missing the film take up cage. Unless I am missing something obvious, I can't see how the film would load properly without a cage like that.
  6. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    1: M/X switch: selects flash sync timing. X=zero delay for electronic flash which will sync at any shutter speed. M=15ms shutter delay (flash fired first) for "medium" class flash bulbs. Popular bulbs of this class at the time of the camera's production were the M-2 & M-3 bulbs (the "M" here is for "minature"). and later the AG-1 bulb (AG=All Glass, also an M-sync bulb).
    2: Film loading is easy but must be done exactly right.
    • First, the empty spool from the last roll needs to be moved from the supply side (bottom position on this camera) to the top were the wind mechinism is. You camera is missing this spool.
    • You then load the new roll in the empty bottom position and pull out the paper leader. The roll must be loaded so that the printed side faces outward. You thread the end of the paper leader into the spool on the take-up side so that it enters the long narrow slot in the spool and exits the short wide slot.
    • You now wind slowly until the big double arrow ( <--> ) points exactly to the two small red dots on either side of the film track just below the image aperture.
    • Now close the back and wind to frame #1 where the wind mech. should lock.
    To find a replacement spool you need to contact a lab that processes 120 film and ask if they have any spare spools (they get one with every roll they process and generally have a number lying around in a recycle bin or set aside for just this purpose. If you live in one of those rare areas where a real camera store still exists, they may have a horde of spools. Otherwise you'll have to sacrifice a new roll of film (some bargin out-of-date roll, perhaps) to get a spool.
  7. BTilson
    BTilson TPF Noob!
    Aug 12, 2008
    467
    Western NC, USA
    Awesome Dwig. Thanks so much for the input!! I really appreciate it.
  8. lucian
    lucian TPF Noob!
    Jun 20, 2007
    24
    west Texas
    Beautiful find. I had one of these when I was in college (68-70). I used it for a lot of portrait work on campus. Outstanding piece of gear.
  9. BTilson
    BTilson TPF Noob!
    Aug 12, 2008
    467
    Western NC, USA
    Thanks Lucian, I appreciate it.
    Dwig, just wanted to let you know that even though I had to sacrifice a roll of film to do so, I got a spool and got my other roll of film loaded successfully. I am very excited now! Thanks so much!
  10. Germ87
    Germ87 TPF Noob!
    Apr 5, 2009
    Hello! My mom just gave the same camera you have today, and Dwig, your instructions on how to load it have been very helpful! However, I'm stuck at the "You thread the end of the paper leader into the spool on the supply side so that it enters the long narrow slot in the spool and exits the short wide slot." part. There doesn't appear to be any difference in lengths of slots on the empty spool...so I'm not sure what to do...
  11. dxqcanada
    Dec 4, 2008
    5,557
    713
    Some spools have the same size opening on both ends.
    Just feed the leader into one end. Wind the crank to take up the film unit the Arrows line up to the dots.
  12. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    As another has said, some modern spools don't have the size difference. Generally the old metal spools, being hollow, used the differing sized slots to reduce the difficulty in getting the paper to pass through the second slot. Modern plastic spools whose spools are solid, at least around the slot, don't need this and simply have a uniform slot all the way through the spool.
    BTW, I should have said "take-up side" instead of "supply side" in this step. The take-up spool is empty and the supply side spool is full when loading.
how to load film into ricohflex
how to load ricohflex
ricohflex film
ricohflex loading film
ricohflex model vi
ricohflex model vi manual
ricohflex model vii
ricohflex model vii manual
ricohflex tlr
ricohflex vi
