Need help with continuous shooting...
Discussion in 'Photography Beginners' Forum' started by GeorgiaOwl, Jun 9, 2008.
  1. GeorgiaOwl
    GeorgiaOwl TPF Noob!
    May 23, 2008
    188
    North Georgia, USA
    My new D60 has a "continuous shooting" mode. I've set the selector to every possible setting....M, S, Auto...and I've made sure I had the CS mode on...
    but when I depress the button to shoot, the camera takes 3 or 4 shots in a row and then stops! I've searched alot of forums, and I have an email in to Nikon support, but maybe it's just something stupid I'm doing - since I can't find anyone else having the problem.
    Any ideas?
    owl
  2. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Do you have auto exposure bracketing on?
    Are you shooting in RAW or JPEG mode?
  3. Overread
    May 1, 2008
    24,009
    4,153
    UK - England
    Are you shooting in RAW?
    RAW files are larger and will fill up the camera buffer quicker than JPEGs so the camera will have to stop to save the files - but you should get more than 3 I think.
    Out of intrest you have not slipped into exposure bracketing mode - that takes 3 shots and you should be seeing a differencein exposures ove the three shots.
  4. Alfred D.
    Alfred D. TPF Noob!
    May 17, 2008
    381
    That's a simple one: the buffer is full!
    The buffer requires time to write your captured images to the card. During that time you cannot expose new images.
    Have fun!
  5. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    You should get six shots if shooting RAW and 100 shots for anything else provided that you're using a Panasonic Pro High Speed memory card. Refer to page 178 of your user manual.
    For a complete list of Nikon-approved memory cards, refer to page 158.
  6. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    The D60 doesn't do automatic bracketing.
  7. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
  8. GeorgiaOwl
    May 23, 2008
    188
    North Georgia, USA
    I'm not sure this model does the bracketing thing. If so, I can't find a setting for it.
    I managed to find the buffer indicator in the viewfinder that shows how many shots you can shoot before memory runs out...it's always at FOUR.
    4 shots?
    Could it be that I need a faster memory card? I'm using a SD Ultra II 1.0 GB card.
    It doesn't matter if I go to 400ISO or 100 or whatever - it still only reads that I can shoot 4 shots in a row before it stops for a memory catch-up.
    thanks guys
    owl
    [edit] - just saw your replies Soc....thanks...
    As for the buffer being full, I understand that, but when Nikon says you can take "100 continuous shots" and the thing stops at 4 ? I don't get it I guess....
    /*scratches head
  9. D-50
    D-50 TPF Noob!
    Feb 15, 2006
    1,043
    New England
    Are you shooting jpeg or raw. that makes a huge difference
  10. GeorgiaOwl
    May 23, 2008
    188
    North Georgia, USA
    jpeg
  11. Socrates
    Socrates TPF Noob!
    Jan 28, 2008
    1,183
    Exit #5
    SD is SanDisk and it should work.
    The buffer indicator in the viewfinder is misleading. It is accurate regarding buffer capacity BUT don't forget that the buffer begins to drain the instant you take a shot. The figures in the user manual are correct with regard to the quantity of continuous shots. (I would expect that different brands would have slightly different results.) My D80 has the same issue with the viewfinder value.
    By the way, don't release the shutter button if you detect a slight additional delay. If you're taking Large/Fine, the spacing between shots will not be consistent. Three or four might fire off rapidly and then maybe a half-second delay for the next one. This results from the buffer fill/drain characteristics. You'll have to experiment a bit.
    Go to the Nikon web site and look for an "800" number to call to get a live person. I've called them several times.
  12. GeorgiaOwl
    May 23, 2008
    188
    North Georgia, USA
    Thanks. If i don't get an email reply, i'll call them.
