My wife just bought a Nikon D200 to break into the digital age. She is a professional photographer using primarily a Mamiya 645 AFD with a SunPak MS-4000 Pro System (2lights). She uses a Wein Pro Sync LX to trigger the flashes with the Mamiya but we can not get it to work right with the D200. It only gives us a picture across a small strip at the bottom. She has been using the built in Flash to trigger her strobes but she gets a shadow cast on the right hand side every time. I am sure you can sympathize with the post procession to remove shadows. She doesn't get this with the Mamiya so she thinks it must be from the pop up flash. What is causing the Pro Sync to produce only the small strip across the bottom and total black above? Is it the pop up flash on the D200 causing the shadow? Where can we learn more about getting good in studio flash pictures with the D200?
Thanks in advance for any comments, tips, tricks, references.
Bruce
Bruce
