Need Help with PS
Discussion in 'Beyond the Basics' started by Algoessailing, Nov 11, 2004.
  1. Algoessailing
    Algoessailing TPF Noob!
    Jul 19, 2004
    64
    NE midwest
    I'm having trouble with my Photoshop Elements 2.0. I am trying to print photos that were originally taken in RAW format, then saved as jpeg with Pentax photolab. After I edit the pics, they look great on my monitor. But when I print them, the resolution is terrible. Its not the printer (Epson Picture mate), because when I print pics originally taken in jpeg format, they look good. Something happens when I resize the photo down to 4x6 (originally something like 26x41). I am able to adjust the pixel/inch, but the higher I go (tried up to 600 from default 72) it seems to just blur the image. Has anyone else had this problem? Any tips? Thanks
    DAve
  2. rangefinder
    rangefinder TPF Noob!
    Jul 3, 2004
    148
    Texas
    I use Elements 1, PhotoShop 4.0 and CS and don't have the same problem.
    QUESTION: What is the resolution of the image you are trying to print?
    I do not resize my images. I crop from the original archived image. So for a 4x6 I crop at 4x6@300dpi.
    Just increasing the image resolution from 72 upward will probably not give you great results. Suggest you crop the original image at 300 dpi and try that. Be sure to save you're 4x6 @ 300 with a different file name to preserve the original image.
  3. manda
    manda instigator of pottymouthedness
    May 25, 2003
    3,330
    11
    sydney
    Im confused. Are you resizing them up or down?
    If smaller, it shouldnt make a difference, but if you're making them bigger, this will always happen.
    All you're doing is stretching them out which will make them blurred and fuzzy.
    If smaller, it should not make a difference.
