Need Perfect Consistent Paper Cutter
twinphotography
Michigan
Website
www.twinphotography.com
I am in desperate need of a consistent paper cutter. I have an old arm cutter that is just not "cutting" it anymore. I have tried a couple others, but am not happy with the results.
Is there one someone could suggest that they just love? Thanks.:thumbup:
Stacy
Get one of those ones that use a wheel that you push down and slide. My mom has one, and it's great for cutting all kinds of pictures. They're cheap too, so replacing it isn't so bad.
Ya i would also recommend using one with a wheel blade. My school has one and its much more accurate than the arm ones. Its also very fast being able to line it up on a plastic guide it has and just zipping the blade down.
Try the Rototrim wheel type cutter. They are quite expensive but are
very precise and if taken care of properly, it will last a lifetime.
Paul
Thanks for the advice. :thumbup:
I have tried a couple wheel ones and just was not comfortable with them. I tried a Fiskars that was about $130- I guess I am just going to have to get used to that type.
Thanks.
Another vote for the Rototrim, very accurate, the best I have ever purchased, however they are more expensive
