Need quick CR2 file help
Discussion in 'Photography Beginners' Forum' started by Breanna, Oct 23, 2009.
  1. Breanna
    Breanna TPF Noob!
    Jan 25, 2009
    210
    A fellow photographer sent me RAW CR2 files on a disk. She uses CS4 and I use CS3. When I try to open the images, I get an error in Photoshop- it says, "Could not complete your request because it is not the right kind of document" ?? Any ideas?? I've never transfered RAWS onto a CD, so I don't have a clue. Could it have something to do with the .xmp file extenstions? Or because I'm in CS3 and she is in CS4?
  2. battletone
    battletone TPF Noob!
    Sep 22, 2009
    285
    Somewhere in the lower 48.
  3. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,448
    15,203
    USA
    Just a thought--maybe you need to transfer the images OFF of the CD and onto a local hard drive. Not sure what Operating SYstem you are using. Are you trying to open the .CR2 files? That is what you should be trying to open, but I think maybe the files need to be on your hard drive and not on a piece of removeable media.
    ALso, if you suspect the .xmp files generated by CS4 are messing up your system, you could remove the .xmp files. I'm pretty sure that CS3 will open Canon RAw files from the 1D series up to the Mark II,and it will also open the raw files of the EOS 5D and 40D and so, maybe if the camera she uses is an EOS 5D Mark II or 50D, perhaps your Adobe Camera RAW module needs the free update.
  4. fokker
    fokker No longer a newbie, moving up!
    Jun 23, 2009
    2,830
    294
    New Zealand
    You need the adobe camera raw update as in battletone's post.
  5. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    correct poster!
    It is your version of Camera RAW is too old for the version the camera needs to use, Ask what camera they were using then we can help more.
  6. beni_hung
    beni_hung TPF Noob!
    Dec 17, 2008
    380
    Lansdale, PA USA
    You may even be forced to buy CS4 to open that type of RAW format. I know PS stopped making updates for one of the CS's so people would have to upgrade.
  7. Dwig
    Dwig TPF Noob!
    Mar 11, 2009
    1,261
    Key West FL
    The Camera RAW update, ACR v5.5, in the earlier reply won't work with PS/CS3. Don't even try to use it in CS3.
    If the OP needs a newer Camera RAW than the last of the ACR v4 offerings there are two choices:
    1. Download the free Adobe DNG Converter and use it to convert the camera specific RAW files into Adobes standardized RAW format. All versions of PS since CS can read the resulting DNG files (PS/CS does require at least ACR v2.2). Links:
    Windows: Adobe - Adobe Camera Raw and DNG Converter : For Windows : Adobe DNG Converter 5.5 update
    Mac: Adobe - Adobe Camera Raw and DNG Converter : For Mac : Adobe DNG Converter 5.5 update
    2: Upgrade to PS/CS4 and then update the ACR v5.0 that ships with CS4 to v5.5. PowerMac users should consider avoiding ACR v5.5 and only updated to v5.4 until v5.6.
    If you aren't regularily having to deal with RAW files newer than your CS3 can handle, the free DNG Converter is probably the better route. Its free. It is an extra step, but can do batch processing of whole folders so its not too much of a chore.
  8. battletone
    Sep 22, 2009
    285
    It appears that while I had originally posted the link for CS4, when I went in to replace it about 2 seconds later with the correct CS3 link, it had only replaced the display text and not the link.
    It was late....I tried. Fixed for future search.
  9. Breanna
    Breanna TPF Noob!
    Jan 25, 2009
    210
    THANK YOU! The DNG conversion worked perfectly! You rock :thumbup:
