Need Recc of a Fast Low Light Lens- Nikon
Discussion in 'Photography Beginners' Forum' started by myvinyl333, Feb 23, 2010.
  1. myvinyl333
    myvinyl333 No longer a newbie, moving up!
    Feb 16, 2010
    534
    32
    Eastern Iowa
    What would add to my Nikon D90? The 50mm is good @ times, as is the 80-200. I need a closer, wider shot in low light?
    Example using the 50 mm:
    [​IMG]
  2. djacobox372
    djacobox372 No longer a newbie, moving up!
    May 4, 2008
    2,925
    129
    Seattle, WA
    How do you get a "closer/wider" shot?? do you mean you want to be closer and hence the shot needs to be wider?
    If you want faster then the 50mm 1.4 you'll need to upgrade to a d700 or d3, to gain better high-iso performance. They'll also make your shot a little wider. If 50mm isn't wide enough for you, then a 35mm f1.4 is your only choice without giving up speed.
    From the look of the one example photos you posted, my guess is the upgrade you'd be most happy with is a new d700 body.
  3. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    Sigma 18-50 f/2.8 HSM Macro
  4. myvinyl333
    Feb 16, 2010
    534
    32
    Eastern Iowa
    Yes, I would like to be closer with a wider shot. Sorry I still lack proper photography language.
  5. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Yo I heard nikon is coming out with this new cheap lens thats just what you want, think its called the 24mm 1.4 afs or something like that
  6. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    Nikkor 35mm f/1.8
    Sigma 30mm f/1.4
    If you go full frame.......
    Primes
    Nikkor 35mm f/2
    Nikkor 28mm, 24mm, 20mm all f/2.8
    Zooms
    Nikkor 14-24mm, 24-70mm both f/2.8
  7. myvinyl333
    Feb 16, 2010
    534
    32
    Eastern Iowa
    Thanks for the suggestions...may I ask what does it mean to go full frame?
  8. kundalini
    Jul 18, 2007
    13,604
    1,933
    State of Confusion
    For Nikon it would be the D700 & D3 + variants (FX) bodies. The sensor size is equivalent to 35mm film whereas the rest of the digital bodies (DX) are a 1.5 crop factor.
    Keep in mind that you CAN use an FX lens on a DX body. However, you will get a Field of View (FoV) multiplied by the crop factor.
  9. JimmyO
    JimmyO TPF Noob!
    Feb 3, 2008
    2,132
    NJ
    Which happens with DX lenses too.
  10. myvinyl333
    Feb 16, 2010
    534
    32
    Eastern Iowa
    Thank you VERY much for clearing that up for me. Now a lot more things make sense. So if I do get another body to add to my D90, a full frame could be an option.:thumbup:
fast lense for nikon d300 in low light
low light lens for nikon d300s
low light lens nikon d300
nikon d300 low light lens
nikon low light lens for d300s
