need recommendations on good polarizing filters
Discussion in 'Beyond the Basics' started by William Petruzzo, Jan 21, 2010.
  1. William Petruzzo
    William Petruzzo TPF Noob!
    Aug 22, 2008
    635
    Washington DC
    I have a commercial client who has me shoot granite installations for her. Until now using creative angles + an inexpensive polarizing filter have been plenty sufficient until today. I had to reschedule one of her clients for the second time, which is painfully unprofessional, because their combination of white cabinets and very dark granite countertops made it impossible to capture usable images.
    So, in order to keep her as a client I'm going to have to get my hands on higher quality polarizers. As a portrait photographer, I don't know much about them.
    Can someone recommend some high quality polarizers that will go a lot farther to minimize reflections than the cheap Tiffen one I'm using?
  2. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    B&W make very high quality CP filters.
  3. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    how about singh-ray
  4. KmH
    Apr 9, 2009
    40,536
    5,541
    Iowa
    I don't know of any filter makers known as B&W, but there is a filter maker known as B+W that makes quality polarizing filters.
    A better polarizer will help but I'd almost be willing to bet the solution is in you lighting setup.
    With no info on your gear/lighting setup though that's just speculation.
    At any rate, you don't need the Kaeseman sealing but be sure to get the MRC coatings: b+w
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
  6. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    Nit Pickers. Actually if you google B&W, you will find links to B+W. :D
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Actually the only link even remotely photography related when I google B&W at Google is Black and White magazine :)
    BLACK & WHITE MAGAZINE | Main Page
    (incidentally a great magazine, there must be something good about all things B and W :) )
  8. davebmck
    davebmck TPF Noob!
    Mar 10, 2008
    678
    Waxhaw, NC
    I have a foxfire extension for google and when I type in B&W, I get a drop down list which includes B&W filters. Selecting that takes me to a google page and the first item on the page is: Schneider Optics - Homefilters/filters_ for_still_photography/. The rest of the page is similar. Results depend on you tools.
  9. willli
    willli TPF Noob!
    Dec 26, 2009
    119
    New York
    if you really one a good CP I will go with Hoya HD they are expensive but are the best polarizer
  10. William Petruzzo
    Aug 22, 2008
    635
    Washington DC
    Thanks for the insight folks.
    Let me elaborate a bit. Basically, all I'm looking for is a filter that will eliminate reflection as much as possible for the most reasonable price. I'm not concerned about sealing or brass casings or anything. The filter will literally only be used for an hour at a time, 2-3 times a week.
    Here are the ones I'm looking at:
    65016931 B + W 82mm Circular Polarizer Wide Angle Slim Mount Coated Glass Filter - for use on my 16-35
    65016930 B + W 77mm Circular Polarizer Wide Angle Slim Mount Coated Glass Filter - for use on 24-70 + 70-200
    These are both 'coated glass' but I'm not sure what that means. If coated is good, does multicoated mean it's even better? Will it make a difference for the filter's intended performance?
    In fact there is no lighting set up. I'm in another company's client's home, so these shoots have to be quick and dirty, so there's no time and usually no need. Natural light does just fine. Large windows are the biggest challenge, but creative positioning usually does the trick, and I'm hoping with the help a better CP filter it will be even less of an issue.
    The kitchen from yesterday was a problem because combination of light cabinets and dark granite. With the right lighting set up, that wouldn't have been a problem, but that solution is null because I neither have the time nor the space to artificially light the kitchen.
  11. William Petruzzo
    Aug 22, 2008
    635
    Washington DC
    Any more insight?
  12. Joves
    Joves No longer a newbie, moving up!
    Dec 14, 2007
    2,399
    21
    Flagstaff/Az
    Yes multi coatings are better. They are there to eliminate reflections between the glass elements. I use the Nikon polarizers as well as Hoya and, B+W. All three have different darknesses to each other. The Nikon is the lightest with the Hoyas being darkest. I love them all and use them as needed for what Im shooting.
