need some help
Discussion in 'The Darkroom' started by darker@, Jul 4, 2008.
  1. darker@
    darker@ TPF Noob!
    Jul 4, 2008
    6
    Slovenia
    hello!
    i was just starting to do some proper b-w photography and i got Fixer Kodak T-Max 1l and Developer Kodak D-76 for 3,8l in pouder. i was wondering can i use this products for both developing the film (negative) and photo paper (pozitive)? Or do i have to have a specific one for either of this steps or all that matters is the different concentration? Also any advice is very welcome and respected :wink:.
    have a nice day.
  2. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    you can use the same type of fixer for both prints or film.
    however developer is usually product specific; i.e. film developer for film ( which is what you have) and paper developers for papers.
    several years ago there was a universal developer but i am not sure if it is still around.
    you indicated Kodak fixer t-max
    just to be sure, there is a film developer by kodak called t-max developer, and then there is kodak fixer. which do you have?
    they are different products
  3. darker@
    darker@ TPF Noob!
    Jul 4, 2008
    6
    Slovenia
    i have a fixer named Kodak T- Max, the name of developer is Kodak D-76. so i guees i have to buy another developer for paper?
  4. ann
    May 14, 2007
    4,263
    189
    yes,a try dektol which is also a kodak product, or perhaps LPD with has a long tray life.
    just pick one stick with the same chemistry until you have a better sense of what can be done with what you have
  5. christopher walrath
    christopher walrath No longer a newbie, moving up!
    Mar 19, 2008
    1,265
    24
    In a darkroom far, far away...
    Just what I was going to suggest, ann.
  6. kaiy
    kaiy TPF Noob!
    Nov 27, 2007
    69
    Developing times using Kodak Dektol for film can be found at the
    Massive Dev Chart at digitaltruth.com
    http://www.digitaltruth.com/devchart.html
    Dektol has the same developing agents as D76, metol and hydroquinone, but it uses sodium carbonate as an accelerator instead of sodium sulfite. The sodium sulfite also acts as a solvent which softens the grain of the film. The net result is that film developed in Dektol will appear to be grainier.
  7. darker@
    darker@ TPF Noob!
    Jul 4, 2008
    6
    Slovenia
    what will happen if i also use developer d76 for developing paper? i was reading literature and realized that back then it was usual to use the same developer for both film and paper so what has changed now? also i read that fixer that i have, thats kodak tmax is only good to use with films? is that true? thank you for your help
  8. ann
    May 14, 2007
    4,263
    189
    since your just beginning i would not recommend using dektol which is a paper developer for film nor a film developer for the paper.
    people have done so but because they are thinking outside the box, which imho , is not a good thing when one just starts out and knows nothing about what a print or negative should look like (no offense here).
  9. Early
    Early TPF Noob!
    Feb 8, 2008
    1,240
    Western NJ
    Paper developer has a higher concentrate of carbonate and hydroquinone and may be too contrasty, or too active for film. Visa versa using D76 for papers. I imagine you can experiment diluting Dektol for film, but I don't see the point unless you want to bring it up in a conversation.:)
  10. JC1220
    JC1220 TPF Noob!
    Sep 13, 2005
    439
    Maine
    The "actual" Kodak formula for D-76 contains no carbonate, but Kodak's balanced alkali - sodium metaborate, or borax as the accelerators. Soduim sulfite as you mention, can act as a mild accelerator and in high quantities a solvent in fine grain developers with no other alkali needed, but it is most commonly used as a preservative, as is its primary intention in D-76.
    Dektol and D-76 may share the same developing agents, but the formulation is quite different, perhaps you are thinking of D-72.
  11. christopher walrath
    Mar 19, 2008
    1,265
    24
    A primary use for sodium sulfite is as a negative wash for some instant film positive/negative type films, ie. Polaroid P/N 55, to wash away the developing paste from the negative.
  12. darker@
    darker@ TPF Noob!
    Jul 4, 2008
    6
    Slovenia
    so give me an advice what cemical products (film developer, paper developer and fixer) are best to start with? we dont have so much choice where i live so maybe just focus on the kodak products, and thank you for your help i think i understand a bit more now
