Need Suggestions on how to improve
Discussion in 'Photography Beginners' Forum' started by RonAriba, Nov 28, 2006.
  1. RonAriba
    RonAriba TPF Noob!
    Nov 28, 2006
  2. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    Welcome to the forum.
    What do you want to improve about them? Do you mean the very bright light coming in through the windows?
    There is just too much of a difference between the outdoor light and the indoor light. You can't capture them both with one exposure. You could add light to the interior...but just turning on the lights probably won't be enough...as you have found. You could use flash, but on-camera flash looks terrible and off camera flash is harder to accomplish.
    You could shut the blinds.
    Another option is to use two exposures. Use a tripod or some support and take two images. On that is exposing for the inside, and one that is exposing for the outside...then use software to combine the two.
    Sun light and your indoor lights are a different color temperature. So if you set your white balance for one type of light...the other will look colored.
  3. RonAriba
    RonAriba TPF Noob!
    Nov 28, 2006
    Big Mike,
    Thanks for your quick responds and suggestions.
    I take pictures for real estate agent for their web-sites and they are commenting/complaining about the bright light coming from the windows. Will photo shop be of any help to balance the light? However, at this time the pay is not enough for me to invest in any other equipment.
    Ron
  4. newrmdmike
    newrmdmike TPF Noob!
    May 8, 2006
    2,107
    it varies.
    everyone i know waits until the light gets the way they want it to be.
  5. ladyphotog
    ladyphotog TPF Noob!
    Oct 4, 2006
    215
    Georgia
    Shoot later in the day and balance for the interior light.
  6. RonAriba
    RonAriba TPF Noob!
    Nov 28, 2006
    I have no control on the scheduling or timing. The real estate agent schedule the time and place. Every house is different, and you do not know what the situation is until you get there.
    Thanks
    Ron
  7. Michael Humle
    Michael Humle TPF Noob!
    Nov 25, 2006
    221
    California
    I think you should try to explain to the realestate agent the realities of photography regarding lighting indoors. As you know, with photography the possibilities are many, however, there are some impossibilities!
  8. danalec99
    danalec99 TPF Noob!
    Mar 14, 2004
    8,345
    68
    The 'bright light' can be controlled by the Shadow/Highlight tool (pull the Shadows slider all the way to the left, and move the the Highlights slider right to your desired position) in PS, up to a certain extent.
    I'd go with Big Mike's suggestion - merge the two exposures.
  9. xfloggingkylex
    xfloggingkylex TPF Noob!
    May 5, 2006
    1,292
    Frederick, MD
    I'd start looking into HRD like mike hinted at. One exposure metered for the indoors with white balance for tungsten light (light bulbs) and the second exposure metered for the windows with white balance set for sunlight. combining the two will result in a picture that is as close to the eye as possible.
    Google High Dynamic Range photo's or photography, and I'm sure others will give you better sites.
    http://www.anyhere.com/gward/hdrenc/pages/img/Apartment_float_l15C.jpg
    the above link is an example of interior shot using HDR techniques. I trust it is EXACTLY what you are looking for.
  10. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    My mother is a realestate. I worry if someone can not sell a house based on the photograph they have being miss-exposed. I had to take a photograph on a camera phone once since mum's camera batteries died on location. The house sold just fine.
    Give him the options. Going HDR is a waste of resources and takes effort and time that I would put into a million dollar home but not into anything less. Exposing for the window means you won't see the house, exposing for the house means a blown out window. In slightly more politically correct words tell him to deal with it or let him know you need to pick better timing if he wants better photos.
  11. mysteryscribe
    mysteryscribe TPF Noob!
    Feb 1, 2006
    6,071
    in the middle of north carolina
    Now if I have this right your camera will snyc a strobe or more than one strob using your on camera light as the trigger. This may have already been suggested but a couple of light weight light stands and a couple of large strobs should deal with your problem. it would take about half an hour the first time to get the setup balanced but after you should able to walk into a room set it up and shoot till your hearts content. A couple of 283's one on each side of you should tame the window lights. It's how I always did it. Of course I fired with sync cords but a couple of optical slaves should work peachy keen.
    Not much whiz bang I know but it will work.
  12. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    There are three main ways to do this... the best is to take the photo early or late in the day, when it balances a little better and is not so harsh. Natural light is the best light, and if it works use it. explain that you need to take pictures at the right time (when the light is balanced ) or you can't take them properly and they will have to live with the glare. 2). Or use photoshop to quieten down the brightness. (I've not tried this , it may work but I think you MIGHT just get a window which looks "Wrong". Don't know but it's worth a try especially if it works.
    3). The last is to invest in some very powerful and very expensive studio flash kit.........................you fill the room with so much bright, white ,even lighting, that the windows loose their power by comparison (Contrast). everything then looks wonderful. You will need to practice with your kit first to get it spot on, and will need a wheelbarrow and a half of money to start with.
    P.S. Like the cactus
