- Joined
- Apr 9, 2009
- Messages
- 41,401
- Reaction score
- 5,706
- Location
- Iowa
- Website
- kharrodphotography.blogspot.com
- Can others edit my Photos
- Photos OK to edit
Doh! :er:
Doh! :er:
Plus center-weighted metering when using strobed light. :scratch:Well according to the EXIF data:
F/16
1/200
ISO 1600
Manual Mode
Flash Fired
You just overexposed the car in the center. Drop ISO and raise the shutter speed a bit.
Well those are some crazy settings
Thank you sir! Best helpful person so far.Brian,
The best advice I can give to you is to take a subject, put your ISO to 200 (or 400 or what ever) put the camera in manual if that's how you want to shoot and set the light metering to center and/or full, get the light meter indicator to "0" (center) and start snapping away. Take a few photos with different shutter speeds and apertures at that "0" then take under exposures and over exposures - go up and down 2 or 3 f stops and shutter speeds. Then change your ISO and do it again. You need to get to know your camera and what the different settings affect.
Since its digital it costs you nothing but time and you will start leaning your camera and photography. Once you start gaining knowledge of both your camera and photography it starts to become easier and natural.
....lens....Should I get a coverage lenses or a photoshoot type lenses? I will mostly be shooting photoshoot.
This is basically "spray and pray" type advice, you find this helpful?
Do you even understand what a full stop of shutter speed is exactly?
My advice, take the money you are going to invest in a lens, and use it on a photography class- you will learn a lot from even a basic course.
For the meantime, set your playback on "highlight" it will cause any blown out areas to flash alerting you that you have lost all detail in that area. This will give you instant feedback.
p!nK
I know that, but I want a good lenses for summer, so I can do more car coverage. I also want to do photoshoots. Should I get a coverage lenses or a photoshoot type lenses? I will mostly be shooting photoshoot.
the other pictures on my flickr do not look like DSLR pictures.
This was not a spray and pray as you suggest it is but a take a photo with your meter reading "correctly" and learn from what happens when you deviate.
