neutral density filter - how do they work
Discussion in 'Beyond the Basics' started by mfacer, May 3, 2005.
  1. mfacer
    mfacer TPF Noob!
    May 18, 2004
    112
    Manchester, UK
    hey...
    I have tried taking a few "bulb" mode shots with my 20d - usually of water falls etc.... but of course they all just come out white!
    I assume I need a Neutral Density filter? Is so, what "x" do I need... there appear to be 2x 4x etc..... I have a 4x for an old camera but never got to use it really.....
    how exactly do they work, and what sort of conditions and settings would one typically use it with?
    thanks for any info :)
  2. lazarus219
    lazarus219 TPF Noob!
    Aug 30, 2004
    215
    Port Macquarie
    a neutral density filter is quite simple, it cuts out light down to a certain amount, basically a x8 will give you 8 more stops to use with your shutter/aperture, which means longer expsures, i assume you want the creamy effect of water which an ND8 will be able to give you but you cvould use something lighter,
    There are also graduated ND filters which are usually more useful for most shots,
  3. mfacer
    mfacer TPF Noob!
    May 18, 2004
    112
    Manchester, UK
    I see.... so if I were to leave the shutter open for 4 seconds, it would effectively be the same as leaving it open for 0.5 seconds? (8x)
    Makes sense!
  4. mentos_007
    mentos_007 The Freshmaker!
    Jun 29, 2004
    9,324
    102
    Poland, Sz-n
    I'll show you:
    [​IMG]
    [​IMG]
    those two shots were taken with NDx4 filter (f9, 1/10 sec) in the midday/ full sun.
    What is more you can brilliantly play with a DOF because it allows you to open the apperture more in the midday. :D
    And as you see in the photos above ND filters do not make any difference to colours, so it is worth buying :D
  5. ferny
    ferny TPF Noob!
    Aug 31, 2004
    8,114
    64
  6. mfacer
    mfacer TPF Noob!
    May 18, 2004
    112
    Manchester, UK
    cool - thanks guys!!
    which would you recommend? Should I get a x4 and an x8?
  7. lazarus219
    Aug 30, 2004
    215
    Port Macquarie
    thanks for the link ferny :)
    I actually knew what ND filters did and everything, but not what the numbers meant and when i went into a shop to find a graduated ND filter the only thing they had was x8 which he told me meant 8 stops (i didnt actually ask he just told me) so i just assumed that was right because i didn't know any better and the shop seemed like a decent photography based shop, its bad now how many shops have people with no idea in them, especially when it makes me screw up and give people wrong advice. sorry!,
  8. Contra|Brett|
    Contra|Brett| TPF Noob!
    Dec 25, 2004
    87
    almost, with an 8 stop filter you would leave it open 2 min 8 seconds or 128 seconds.
    for that effect however, your meter reading would be something like 1/250 so 8 stops down is
    1/125
    1/60
    1/30
    1/15
    1/8
    1/4
    1/2
    tada, one second shutter speed.
how do nd filters work
how do neutral density filters work
how do neutral density filters works
how do the work neutral density
how does a neutral density filter work
how it works neutral density filter
how neutral density filter works
how neutral density work
how they work neural density filters
what number neutral density filter do you need
