New Camera Soft Images 40D????????????/
Discussion in 'Photography Beginners' Forum' started by arron06, Mar 20, 2008.
  1. arron06
    arron06 TPF Noob!
    Oct 27, 2006
    26
    Canon 40D & Sigma 28-300mm 1:3.5-6.3
    the images seem to be quite soft??
    any help and has anyone else had this ?????
    Arron
  2. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    You'll have to post some samples, along with the EXIF data (iso, shutter speed, aperture, focal length, etc)
    Lenses with gigantic zoom ranges like that "tend to" not have the best image quality so that could be part of it, but it could also be technique related.
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Yes, you will have to post some examples with the EXIF data, for us to have any idea of what the problem is.
    My first though it that your shutter speeds probably aren't fast enough for that lens and my second thought is that that lens is not doing you any favors in terms of quality.
  4. LeftyRodriguez
    LeftyRodriguez TPF Noob!
    Aug 21, 2007
    97
    Dallas, Texas
    Also, are you doing shooting in RAW or jpeg? Doing any post-processing such as sharpening? Sharpening can be a huge help.
  5. KhronoS
    KhronoS TPF Noob!
    Oct 8, 2007
    345
    Romania, Galati
    Try not to use the maximum aperture.. i mean for 28mm try using f/7.1 in stead of f/3.5..
    Another huge tip, try using a tripod...
    Like other above said, post some examples...
  6. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,700
    68
    Missouri
    I flat out guarantee you that the problem isn't with the 40D... it is with your shooting technique and/or your lens.
    I agree with the others, examples and EXIF data please so we can put our heads together on it and help you out.
  7. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    well, I would normally say it's probably user error. But with this camera, the single most biggest complaint is soft images. I returned my first body and the second was fine, however it still does not produce the same sharpeness as my 30D with the 100-400 @ 400mm.
    Try to do another test using mirror lockup on a solid tripod and also use Live View at 10x.
    Look into performing a more accurate test
  8. arron06
    arron06 TPF Noob!
    Oct 27, 2006
    26
    how do i attach a image with EXIF???
    thankyou for the help all
  9. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    Exactly.
    what is your in camera sharpening set to? you have to decide if you sharpen in-camera on the fly, or if you sharpen on your computer when you downloaded them from the camera.
    Bayer-pattern sensors do produce an image, which is not tack sharp. if you sharpen automatically in camera, you have no control ... you might lose information in fine structures if the sharpening is overdone. hence I would suggest to do all the sharpening outside your camera, adapted to the image you shot.
  10. JIP
    JIP No longer a newbie, moving up!
    Aug 29, 2006
    3,019
    Pittsburgh PA
    it is vry simple upload an image to a site loke photobucket and click on the little mountain and place it here. There is a more extensive tutorial here http://www.thephotoforum.com/forum/showthread.php?t=76568 . And I tned to agree, not having anyexperience with the 40D personally you might have a shutter speed issue especially with the lens you are using. My question is why would you put a lens like that on such a nice camera.
