MyOwnPath
- Joined
- Apr 29, 2004
- Messages
- 27
- Reaction score
- 0
I just got a lens from ebay and have some questions someone may be able to clear up.
I'm actually baffled...looking through the lens (off the camera), it is clear that when I adjust the aperature ring, the aperature opening itself does not change. On all other lenses I've used, you can see the aperature change as you adjust it.
However, when the lens is on my camera and I adjust the aperature ring, the light meter reading changes. So it must be doing something. Could it be that the aperature snaps back to it's smallest setting when I remove it from the camera? Why doesn't the ring adjust it off the camera? The ring moves, so it isn't stuck on aperature priority.
In looking through the viewfinder with the lens on, it is very dark. I have a similar lens by another maker that I'm comparing it to. when I use it inside, I can barely see anything and when outside, bright lights and backgrounds are dull grey. I do a lot of evening photography and need a lens that registers light clearly. I may just be missing something, but compared to all others I have used, this lens is confusing me. Thanks.
--Trav--
--Trav--
