New RAW Format
Discussion in 'Beyond the Basics' started by MDowdey, Sep 27, 2004.
  1. MDowdey
    MDowdey Guest
  2. PrimaryCanary
    PrimaryCanary TPF Noob!
    Aug 29, 2004
    145
    Caution: Contents Under Pressure
  3. bshearer
    bshearer TPF Noob!
    Jul 27, 2004
    46
    RAW is losless correct?
    So there should not be a problem with them becoming obsolete.
  4. Big Mike
    Dec 16, 2003
    33,872
    1,823
    Edmonton
    You may not loose any information when the camera saves the files in RAW format...but you still need software to read that RAW file. If they change the RAW format the software will follow and eventually it may be hard to find software to read the files created in the "older" RAW format.
    Right now, I think, there are different RAW formats. ie:Canon RAW, Nikon RAW...etc.
    I guess people could avoid a problem if they always keep the soft ware that is compatible with their store of RAW files.
  5. voodoocat
    voodoocat ))<>(( Supporting Member
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    You could always go back and get the software that can read the proprietary RAW file and convert it.
  6. PrimaryCanary
    Aug 29, 2004
    145
    When I wrote
    I meant that you would lose the ability to view the image or convert it or work on it. Much like you can't use software that was made for a windows 3.1 on windows XP (difference between a 16-bit and 32-bit executable) Maybe a better example would be how Apple has made the floppy drive obsolete by not including it with their new desktops and laptops. If you had a floppy disc with some images on it, you'd have to find either an external floppy drive (which do exist and aren't hard to find) or lose the images. Let's say next year Canon decided to make a completely new RAW format and stopped distributing it's old RAW software, and by chance I lost my copy of my RAW conversion software. Now all my RAW images based on the old format would be useless. Now that's an extreme case, but it illustrates the point I was trying to get across...I think
  7. bshearer
    bshearer TPF Noob!
    Jul 27, 2004
    46
    voodoocat,
    exactly. I think if a universal RAW format was ever adopted, the major players (Cannon, Nikon, Pentax, Minolta, etc...) would come out with a conversion utility.
    But doesnt each manafacture taylor thier Raw utilities to work best with their own stuff? Like Pentax's utility for adjusting whiteballance, is tuned to work best with images that come straight from pentax cameras. If it were universal, then I see a polification of software compents that work best on adjusting certin aspects of images coming from specific manafactures, so why should they even bother conforming to a universal RAW when they can keep you locked into their software.
  8. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    I just don't think it's that big of a problem to even be an issue. I can still go find astroids, which was programmed in the 70's for an arcade console and play it on my pc. Compatibility is a non-issue in this case.
  9. Geronimo
    Geronimo TPF Noob!
    Jun 8, 2003
    1,329
    Next to the point of no return.
  10. Daniel
    Daniel TPF Noob!
    Jun 14, 2004
    189
    Dublin
    It's more like someone speaks Russian and you skeak English. You might say the same, but using a different language. The information is the same, but you still don't know what they are talking about. If you agree on a same language, everyone understands each other.
    The problem with becoming obsolete is not the RAW format, but the software to read that format. As stated by someone earlier, try to run software that was made for Windows 3.1 on Windows XP.
  11. jadin
    jadin The Mad Hatter
    Feb 18, 2004
    1,740
    9
    Down the Rabbit Hole.
    It's no different than gif files, bmp files. Sure they're old, but can you still find software that reads them? You bet. Are they industry standard right now? Not exactly.
    As far as the windows 3.1 analogy goes.. true, but that doesn't mean you can't find copies of windows 3.1 to open those programs.
    Standards will change, ability to access old standards won't.
  12. voodoocat
    May 15, 2003
    5,277
    17
    Gilbert, AZ
    Name one program that was written for windows 3.11 that wont run on XP? I could still play DOS games on my machine. Did you ever look at your options for "save as" in microsoft word? Word will read pretty much any word processor file.
