Newbie having issues with lens on fujifilm? Help please.
Discussion in 'Photography Beginners' Forum' started by emd_10, Apr 2, 2009.
  1. emd_10
    emd_10 TPF Noob!
    Apr 2, 2009
    5
    While my Fujifilm S700 isnt the most expensive camera in the world, I love it, and I love taking photos! My husband bought me a 0.5 wide angle lens and Im getting a dark shadow at the bottom, can I do anything to prevent that?
    Without lense
    [​IMG]
    With lens
    [​IMG]
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Welcome to the forum.
    I guessing this only happens when you use flash? My guess is that the lens accessory is partially blocking the flash, which is why it's a circular pattern at the bottom of the image.
  3. emd_10
    emd_10 TPF Noob!
    Apr 2, 2009
    5
    Ive tried without the flash, if it doesnt flash its incredibly blurry. What would be causing that?
  4. emd_10
    emd_10 TPF Noob!
    Apr 2, 2009
    5
    Thanks for the welcome. Forgive me if my questions are stupid, im still very new at this.
  5. Dao
    Dao No longer a newbie, moving up!
    Mar 24, 2008
    6,252
    418
    St. Louis
    Yes, the dark spot is the shadow of the add-on lens.
    And that is the limitation of the camera I believe. It need flash for low light situation. But the add-on is too long for the build-in camera flash.
    So looks like add-on lens and the flash cannot be use together.
  6. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    The cause of your blurry shots, is a slow shutter speed. A slow shutter speed is often required when there isn't enough light. When the flash is used, it freezes the motion, so you don't get the blur...but since the flash is so close to the camera, you get flat light, which isn't very nice.
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    It's not so bad...it's only on the very bottom of the image. Might not be an issue for many shots and it can always be cropped out.
  8. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    Also the quality of the add-on lens doesn't seem to be good.
    A lot of Chromatic Aberrations (CAs)
  9. Dao
    Mar 24, 2008
    6,252
    418
    St. Louis
    I guess yes. The bottom of photo can be cropped out :)
  10. emd_10
    emd_10 TPF Noob!
    Apr 2, 2009
    5
    Thanks for the advice. If anyone wants to reccomend any other good lenses compatible with my camera, I love taking close ups. :D
    It doesnt seem to be leaving the shadow outside even with the flash going off, so looks like that will be its main purpose.
  11. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    The flash probably doesn't register very much when outdoors, unless it's dark out.
    For the most part, I don't like the idea of those 'lens adapters' for cameras like yours. The quality usually isn't great, so it hurts the image. The wide angle adapter is OK, because it it gives you something that you can't otherwise get...but I'd forget about anything else...well maybe a polarizing filter.
  12. emd_10
    emd_10 TPF Noob!
    Apr 2, 2009
    5
    Ill look into a polarizing filter. Eventually i'll probably get a more expensive camera, but for now this one is great. Im happy with the picture quality, and not overly stressed if dropped while chasing around my walking tornado little guy.
    Thanks for the advice. :)
